IAP 225 - Eth0 and Eth1 active two different Switches
  • 1.  IAP 225 - Eth0 and Eth1 active two different Switches
    Posted Sep 25, 2016 05:53 PM
    Dear community,
    during a PoC a critical requirement arose having both ports active where Guest Traffic is leaving on Eth1 to a local breakout an Corporate Traffic is leaving to Eth0.
    Both Ports are connected to two different Switches which are not connected together.
    I tried doing so by creating wired profiles pointing to each Eth Port without success.
    The latest Instant Release 6.5.x.x 4.3.x.x has been installed.
    Two different SSIDs will be applied at the end.
    kind regards
    Giancarlo Lume
  • 2.  RE: IAP 225 - Eth0 and Eth1 active two different Switches
    Posted Sep 25, 2016 05:55 PM
    You are trying to have two different uplinks for user traffic?
  • 3.  RE: IAP 225 - Eth0 and Eth1 active two different Switches
    Posted Sep 25, 2016 06:27 PM
    Yes exactly.
    Viele Grüße
    Giancarlo Lume
    Bechtle GmbH & Co. KG, IT-Systemhaus Rottenburg, Phone: +49 7457 9387-770
    Von meinem iPhone gesendet
