IAP 225 & IAP 325 Processors
  • 1.  IAP 225 & IAP 325 Processors
    Posted Feb 21, 2016 06:19 AM
    What are  the  Processor and RAM configuration  for below IAP's
    IAP-205
    IAP-215
    IAP-225
    IAP-325
  • 2.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 21, 2016 07:26 AM
    IAP-205 - 128MB sdram 32MB   Flash   Broadcom BCM53014
    IAP-215 - 256MB sdram 32MB   Flash   Freescale P1010
    IAP-225 - 512MB sdram 32MB   Flash   Freescale P1020
    IAP-325 - 256MB sdram 128MB Flash   QCA IPQ8064
  • 3.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 21, 2016 02:13 PM
    Thankyou  colin for  your response  .
    can you tell us  which  is better in terms of  processing between  IAP-225 & IAP-325  as  i can  see  better RAM  in  IAP-225 but  probably  better processor in  IAP-325
  • 4.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 21, 2016 07:11 PM
    There is nothing really that can be derived from the CPU and Memory.
    Please see the comparison page here:  http://www.arubanetworks.com/products/networking/access-points/compare/#29199,19347
    The AP325 can handle 802.11ac wave 2 clients and it has a built in bluetooth beacon that can either serve as a beacon, or manage other bluetooth beacons.  Please see the AP325 datasheet here: http://www.arubanetworks.com/assets/ds/DS_AP320Series.pdf
  • 5.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 11:56 AM
    how can we say  that  nothing can be derived from  RAM and  processor  ...dosnt that count for  better performance   and capability
    Thank you
  • 6.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 12:01 PM
    Proper design is really the most important piece.
  • 7.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 12:33 PM
    yes  sure design is very  important  but think  if i have  planned well but  with  an AP  having  16kb of ram with  a very  poor processor ..than  do  you  think  that  my  design  or  planning is going to make any   difference  obviously not  .
    Please tell me  in the light of your experience/knowledge that  325 with  low memory  (256Mb ram) will  give  better  performance  or 225  with  comparatively (512mb) high  memory will  do better  performance , processors should also  be considered  .
    you can  assume  that  i have  no  11ac clients only  11b/g/n clients are  present ...
  • 8.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 12:48 PM
    How many clients per cell in your design?
    Sent from Nine
  • 9.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 01:00 PM
    i am  planning  60  clients  per AP  ..but  its not what  i am  thinking of ...i am  trying  to  plan for the situation  when  density of  user per IAP increase  drastically so in such  situation  a  giant  AP (better  performance/capability) is  required  .
    i hope  i am  clear now  as  for  60  clients  AP -205 would  be   enough  , but  i am  discussing 225 and 325  just  because  i  am  expecting  250 to  300   users in the  coverage  of single IAP .
  • 10.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 01:37 PM
    If you are planning high density with a/b/g clients with 60 clients per ap, you are limited by:
    54megs/2/60 = .45 megabits of traffic per client.  That is under perfect conditions before you factor in any interference.
    If you are planning on a/b/g/n your formula would be
    130megs/2/60 = 1.08 megabits per client if they are all 2 stream 802.11a/n clients.  This is under perfect conditions and if no a/b/g clients associate to that access point.  If you limit it to 30 clients, you can at least get 2.1 megabits/client.
    Long story short, planning for 60 users per AP does not give you much room for performance and you should not really plan like that if you expect any measure of performance.  It is the RF and the client capability that is limiting this performance, not the CPU
    Are you working with a local Aruba resource on this project?  If so, they can steer you the right way.
  • 11.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 29, 2016 03:43 AM
    no answer
  • 12.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 29, 2016 09:18 AM
    No answer? No answer to what? Sorry I'm not following. The answers provided seem to be sufficient to cover the original question. Was there a new question?
  • 13.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 01:26 PM
    The 325 you can think of as an AP225 that can service 802.11ac wave 2 clients.  From an RF perspective, It should similar if you have all 802.11a/b/g/n/ac clients.  You would get an AP325 if you would want to futureproof by getting 802.11ac wave 2 capabilities...
  • 14.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 22, 2016 01:23 PM
    Thank you
      The software determines how the hardware works, so looking at an AP based on CPU and memory does not automatically guarantee "better" performance.
  • 15.  RE: IAP 225 & IAP 325 Processors
    Posted Feb 21, 2016 04:27 PM
    325
    #AirheadsMobile
