IAP 225 + IAP275 bad connections
  • 1.  IAP 225 + IAP275 bad connections
    Posted Jun 27, 2015 04:19 AM
    I have in my home  IAP 225 and for outside a IAP275.
    My problem is that i have a bad connection, i have pings (they seem to come in waves) ranging from 2ms to 400+ ms (and timeouts) towards the internet. The same pings show when i try to ping my ap's
    Even when im sitting outside directly under the IAP275 in line of sight (2 meters) i still have the same bad connection. I have some interference on the 2,4 band, but i dont have that on the 5 band which is showing the same issue...
    In my home i have other "wireless" products:
    Philips HUE
    Netatmo
    Honeywell Evo Home
    Gigaset wireless phones
    I have no idea were to start to get this solved..
    I hope you have :(
    Regards
    Hans
    #AP225
  • 2.  RE: IAP 225 + IAP275 bad connections
    Posted Jun 27, 2015 04:55 AM
