IAP 225 realease date
  • 1.  IAP 225 realease date
    Posted Jul 21, 2013 10:59 AM
    When this will be out to buy ?
    Cheers
    Carlos
    #AP225
  • 2.  RE: IAP 225 realease date
    Posted Jul 21, 2013 11:21 AM
    No exact ETA, however, it should be available within around 2 - 3 months.  Stay tuned.......
  • 3.  RE: IAP 225 realease date
    Posted Jul 21, 2013 12:40 PM
    Thank you for the update marcus!
  • 4.  RE: IAP 225 realease date
    Posted Jul 23, 2013 10:40 AM
    Can AP-225 switch to IAP-225 through firmware upgrade?
  • 5.  RE: IAP 225 realease date
    Posted Jul 24, 2013 09:31 PM
    Nope.  A controller-based version of the AP can only be a controller-based AP.   An IAP, however, can be converted to be controller-based and revert back to an IAP using the reset button on the back of the IAP.
  • 6.  RE: IAP 225 realease date
    Posted Sep 17, 2013 11:06 AM
    Just thought I would post an update.   The IAP-22x and IAP-11x should be out by mid-November.  They require IAP v.4.0 which should be out by the end of October.
  • 7.  RE: IAP 225 realease date
    Posted Nov 14, 2013 03:05 PM
    Any update to the release date?
