IAP-225 will not let me log in
  • 1.  IAP-225 will not let me log in
    Posted Aug 26, 2015 06:48 AM
    I was about to log in and check to see if there was any new firmware - I am unable to log in to the web interface. The credentials are correct and when I click the "Log In" button, the dashboard starts to appear then quickly snaps back to the login box. I know that the credentials are correct because If I deliberately put in the wrong ones, I only get the red text in the login prompt telling me I got it wrong.
    I tried rebooting the main (first) AP and the result is the same.
    I tried clearing the cache also.
    Any thoughts?
    #AP225
  • 2.  RE: IAP-225 will not let me log in
    Posted Aug 26, 2015 06:50 AM
    What was the last thing you did before this happened?
    When was the last time you could log in successfully?
  • 3.  RE: IAP-225 will not let me log in
    Posted Aug 26, 2015 06:53 AM
    The last time was approximately a month ago when I applied the latest firmware. I don't recall what versions I went from - and to.
  • 4.  RE: IAP-225 will not let me log in
    Posted Aug 26, 2015 07:04 AM
    Oddly enough, I tried using the IP address of another IAP and got in to the dashboard.?!?! I had to go through a couple of different IP addresses for other IAPs, but found one that worked.
    The firmware version is 6.4.2.6-4.1.1.7_50209.
    Do I try to upgrade them all again and hope for the best??
