Iap-225 wired port stays down
  • 1.  Iap-225 wired port stays down
    Posted Jun 08, 2016 05:53 AM
    I have a Iap-225 with software version 6.4.4.4-4.2.3.2_54910. I run this version because i wanted to disable the broadcast of the SSID's on specific times.
    Im trying to set up my ENET1 port as a bridge port. But when i plug in my laptop on this port it stays down. If i reboot the IAP i can see the port goes up for a short time and then goes down again.
    My setup:
    So i created a new wired profile (bridge) with the following settings:
    Employee
    POE: Disabled
    Admin status: UP
    Under advanced settings:
    Content filter disable
    Uplink Disabled (tested also with enabled)
    On the VLAN page i use Access port.
    I tryed both options: virtual controller managed as network assigned
    Security tap is default and access tab is unrestricted.
    Now this profile is created i bind it to interface 0/1.
    I have not tested it with another software version yet. Any Idea?
    When i do a show wired-port-settings:
    Wired Port Profiles
    Name                        VLAN Mode  Allowed VLANs  Native VLAN  Admin Status  Role                        Speed  Duplex  POE  In Use  Authentication Method  STP
    wired-instant               Access     all            guest        Up            wired-instant               auto   auto    No   Yes     None                   No
    default_wired_port_profile  Trunk      all            1            Down          default_wired_port_profile  auto   full    No   Yes     None                   No
    bridge                      Access     all            guest        Up            bridge                      auto   auto    No   Yes     None                   No
    Port Profile Assignments
    Port  Profile Name
    0     default_wired_port_profile
    1     bridge
    2     wired-instant
    3     wired-instant
    4     wired-instant
  • 2.  RE: Iap-225 wired port stays down
    Posted Jun 08, 2016 06:07 AM
    Are you using high-powered POE to power your AP-225?  If not, it will bring the second interface down.  Check the "show tech-support" to see if that is what is happening:
    Power Status
    Operational State          POE-AF: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
    Current HW State           POE-AF: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
    LLDP Negotiated POE Power  13.0W
  • 3.  RE: Iap-225 wired port stays down
    Posted Jun 08, 2016 06:16 AM
    Thats it. Problem solved. Thank you!
