IAP-225's will not join IAP-205 Cluster
  • 1.  IAP-225's will not join IAP-205 Cluster
    Posted Sep 14, 2015 04:42 PM
    I have a cluster of 11 IAP-205-US's. I have 5 IAP-225-US's that will not join the cluster.
    If fact, the 225's will not get (And keep) an IP from a DHCP server, so I cannot communicate with them at all, or at least not easily. If I put one of the problem AP's and a computer on the same VLAN, the computer ends up getting an IP in the subnet 172.31.98.0/23 (this must be being assigned form the AP/VirtualController). For example, last time I did that, my IP was 172.31.98.164. When I browse to https://172.31.98.1 (which is my computers DHCP assigned gateway), I am able to get on a VC that shows the one AP. Interestingly though, the AP has an IP of 169.254.0.0/16 (the default "I can't get an IP" subnet).
    From the VC in the strage setup described above, I was able to update the firmware on that AP to the same version as those on my 11x 205 cluster (6.4.2.6-4.1.1.9). BUT, when resetting and putting the 225 back on the 205 cluster vlan, even if I "clear defualts" (which the VC/GUI says is equivelant to a factory reset), it does not join.
    The only way I can talk to that AP again is to jump on a VLAN without a DHCP server, wait to get an address from the 172.31.98.0/23 subnet, and then go to https://172.31.98.1
    I have not physically reset any of these five 225 AP's because they are mounted 30-40 ft up and my wiring guys have already left the job site with their extension ladders and lifts. The GUI says clearing the config is equivalent to a factory reset though.
    Not sure it means anything, but we're using PoE, not PoE+.
    My questions are:
    -Was resetting the AP from the GUI the same as holding the reset button on boot?
    -If not, is there another way to reset it completely without physically touching it?
    -Is the 172.31.98.0/23 a standard subnet for Aruba, or is that clearly some remnant of someone else' config still residing on the AP/VC (one of the 225's was previously used, so that is my fear)
    -If I set the AP to a "standalone" AP (as an available option in the VC/GUI) and then "clear the defaults", could that do any good? My thought with this is that it may kick it off whatever cluster it thinks its a part of)
    #AP225
    #AP205
  • 2.  RE: IAP-225's will not join IAP-205 Cluster
    Posted Sep 14, 2015 04:45 PM
    Do you have the IAP205 and 225 using the same level of code?
    Also make sure that the network on 225's isn't connected to E1
  • 3.  RE: IAP-225's will not join IAP-205 Cluster
    Posted Sep 14, 2015 04:48 PM
    By level of code, do you mean firmware? If so, they're all on 6.4.2.6-4.1.1.9
    And using the E1 port would cause this issue? So I will need to physically look to see if they are connected to that port or not?
  • 4.  RE: IAP-225's will not join IAP-205 Cluster
    Posted Sep 14, 2015 05:18 PM
    BTW, my install guys just let me know that they indeed plugged all the 225's into e1 :/ I'm going to head to the site with a lift and switch them all over. I'll let you know if that's the issue. Thanks!
  • 5.  RE: IAP-225's will not join IAP-205 Cluster
    Posted Sep 14, 2015 06:30 PM
    When you use E1 it causes the AP to not form a cluster in a non-lacp setup.
  • 6.  RE: IAP-225's will not join IAP-205 Cluster
    Posted Sep 15, 2015 02:29 AM
    That was it: our installers hooked all the 225's up to E1 instead of E0. Thanks for your quick response!
  • 7.  RE: IAP-225's will not join IAP-205 Cluster
    Posted Sep 14, 2015 05:12 PM
    E1 only works or gets activated if POE+ is being supplied to the AP but E0 is the main uplink port to use to power the AP. E1 can be used for LACP in cases where it is needed.
