IAP-228 with two external antennas
  • 1.  IAP-228 with two external antennas
    Posted Jul 25, 2018 04:06 PM
    Hello friends,
    Can someone say if  is it a really bad experience to use only two external omni antennas at IAP-228 (it has six RPSMA connectors)?
    Or can I save some investiment using only two antennas instead of six? and keep a good performance ?
    Thank you very much!
  • 2.  RE: IAP-228 with two external antennas
    Posted Jul 25, 2018 05:16 PM
    The AP-228 has discreet radio antennas (not dual-band like many other external antenna models), so just using 2 omni-directional antennas will either reduce the radio performance to a 1x1:1 on both bands, or will eliminate one band and provide 2x2:2 on the other. Regardless, performance will be less than if all antennas where connected/used.
    If you leave antenna ports disconnected, remember to add terminators on the unused ports.
  • 3.  RE: IAP-228 with two external antennas
    Posted Jul 25, 2018 06:41 PM
    may i understand are these terminators inclusive in the purchase of a AP??
  • 4.  RE: IAP-228 with two external antennas
    Posted Jul 26, 2018 09:10 AM
    Terminators are not included with the AP, as all antenna connections are expected to be used.
  • 5.  RE: IAP-228 with two external antennas
    Posted Jul 26, 2018 10:30 AM
    * Probably we have to find those termitors in the market, right? As we don`t have it in the Aruba portifolio.
  • 6.  RE: IAP-228 with two external antennas
    Posted Jul 26, 2018 10:32 AM
    Yes, that's correct.
  • 7.  RE: IAP-228 with two external antennas
    Posted Jul 26, 2018 10:28 AM
    Four of the six antennas, wouldn't help much right?
  • 8.  RE: IAP-228 with two external antennas
    Four would be better, yes.
