IAP 2.4 & 5ghz led Orange - not show in VC
  • 1.  IAP 2.4 & 5ghz led Orange - not show in VC
    Posted Nov 14, 2016 02:38 PM
    We have a problem, implemented 40 iap 103s with firmware 4.1.1.13
    30 iaps are shown in the Instant VC, while the other 10 are not shown in VC
    We checked - all AP's do have an IP in LAN via dhcp
    We can ping those devices as well.
    If we surf to onw of those 10 AP's IP adresses, we are redirected to the VC Iap his IP address.
    The leds on those 10 iaps are as follow: poer and eth are green, 2.4ghz and 5ghz are orange.
    Even if those 10 iaps came shipped with other firmware, after being connected as last to network, they should receive VC his firmware version. Corewct?
  • 2.  RE: IAP 2.4 & 5ghz led Orange - not show in VC
    Posted Nov 14, 2016 02:40 PM
    Ssh into an ap with a problem and type "show log system" and "show log provision" to see what the problem could be.
  • 3.  RE: IAP 2.4 & 5ghz led Orange - not show in VC
    Posted Nov 14, 2016 02:47 PM
    Thanks for the response, will check tomorrow.
    Ps should they have to login: admin/admin or will they have the password that has been set for VC?
  • 4.  RE: IAP 2.4 & 5ghz led Orange - not show in VC
    It depends of the have joined the VC or not.
  • 5.  RE: IAP 2.4 & 5ghz led Orange - not show in VC
    Posted Nov 15, 2016 08:25 AM
    Hi i have added the output of thise commands for one IAP (one of the 9 IAPs that don't show up in the VC).
    I have editted the files with xxx for IP adresses for privacy concerns.
    Attachment(s)
    txt
    show_log_provision.txt   723 B 1 version
    txt
    show_log_system.txt   4 KB 1 version
  • 6.  RE: IAP 2.4 & 5ghz led Orange - not show in VC
    Posted Nov 15, 2016 08:41 AM
    AP not allowed, turn off master election
    Are you allowing all APs to join the cluster?
  • 7.  RE: IAP 2.4 & 5ghz led Orange - not show in VC
    Posted Nov 15, 2016 08:48 AM
    In instant > System > Auto Join is Enabled
    So yes we allow all IAPs to join VC..
