IAP 275 DHCP L2 ISSUE
  • 1.  IAP 275 DHCP L2 ISSUE
    Posted Jan 02, 2015 02:14 PM
    Hi and happy New Year.
    I have a small cluster of 3 IAP 275, i use only the native VLAN 1 , and I use the following config
    • Virtual controller IP : 10.10.29.254/24
    • IAP 1 : 10.10.29.253/24
    • IAP 2: 10.10.29.252/24
    • IAP 3: 10.10.29.251/24
    I was using the Local layer 2 mode, but when configured I got an error message “that I do not remember”
    • What can be the issue.
    • I noticed that I cannot do a dhcp reservation of more than one IP address , have I missed something.
    Thank you in advance
  • 2.  RE: IAP 275 DHCP L2 ISSUE
    Posted Jan 05, 2015 05:03 AM
    Hi Friend,
    To understand your issue more clearly, please provide the following information,
    1. Are you using a IAP-VPN with the controller ?
    2. What is the IAP and controller code you are using ?
    3. Why do you want DHCP reservation ?
    Please clarify the above.
