IAP-275 hangs at boot in console
  • 1.  IAP-275 hangs at boot in console
    Posted Apr 03, 2018 07:17 PM
    I am having trouble getting an IAP-275 to apboot for software upgrade even after reset button powerup reset it hangs in boot just at memory test - is memory bad? is it field replaceable?
    in console it gets this far and hangs and auto restarts looping:
    APBoot 1.5.3.14 (build 46206)
    Built: 2014-09-26 at 18:50:05
    Model: AP-27x
    CPU0:  P1020E, Version: 1.1, (0x80ec0011)
    Core:  E500, Version: 5.1, (0x80212051)
    Clock:
           CPU0: 800 MHz
           CPU1: 800 MHz
           CCB:  400 MHz
           DDR:  333.333 MHz (666.667 MT/s data rate) (Asynchronous)
           LBC:   25 MHz
    L1:    D-cache 32KB enabled
           I-cache 32KB enabled
    I2C:   ready
    DRAM:  Configuring DDR for 666.667 MT/s data rate
    DDR:   512 MB (DDR3, 32-bit, CL=5, ECC off)
    the next step should be :
    POST1: memory passed
    but it never gets there
  • 2.  RE: IAP-275 hangs at boot in console
    Posted Apr 03, 2018 08:25 PM
    The memory isn't field replaceable, however, the unit does have a limited lifetime warranty. It may be easiest just to open a case with TAC and get the unit replaced.
  • 3.  RE: IAP-275 hangs at boot in console
    Posted Apr 05, 2018 12:39 PM
    Charlie is correct, just open TAC and get a replacement AP under the LLW.
  • 4.  RE: IAP-275 hangs at boot in console
    Posted Apr 06, 2018 07:07 AM
    Thanks for the reponse we are working on the details.
  • 5.  RE: IAP-275 hangs at boot in console
    Posted Apr 06, 2018 07:06 AM
    Thanks! It appears this is an older Dell unit that wasnt installed (old Stock), is that still covered now by HPE? We are researching original purchase info...
  • 6.  RE: IAP-275 hangs at boot in console
    Posted Apr 06, 2018 10:28 AM
    The warranty should still be honored by Dell. If purchased/branded as Dell, I would start there.
