Dear All, i have try the mesh with IAP 275 using the Firmware version 6.4.3.1 , but it was not working at all , have any one of you tray it before. Regards
Need clarification if you are using Instant OS or Aruba OS?
Dear,
I'm using the IAP version 6.4.3.1 , it is supposed that it support the mesh.
what is the relation between Extended SSID and mesh , do i have to disable it ?!
Regards
thank's folks , i have resolve the problem.
by default the extended SSID is enable , by disabling it the mesh works correctly.
