IAP-275 Power Cords
  • 1.  IAP-275 Power Cords
    Posted Jun 09, 2015 10:43 AM
    Aruba is charging $200+ for a power cable and plastic connector.  Has anyone found an alternate source for this cable?
  • 2.  RE: IAP-275 Power Cords
    Posted Jun 09, 2015 02:40 PM
    When you say it like that it sounds outrageous but aren't you getting a 802.3at power injector with that power cable and piece of plastic?
    I know you can get a low end poe+ switch for less than that which could help if you are powering more than one 275.
    -Rosie
  • 3.  RE: IAP-275 Power Cords
    Posted Jun 10, 2015 10:16 AM
    We'll be installing several IAP-275 in a mesh configuration.  Only the first will be powered by POE.  Each additional device will be powered independently and need a power cord.
  • 4.  RE: IAP-275 Power Cords
    Posted Jun 11, 2015 06:28 PM
    mesh support is not available yet with IAP-2XX series instant APS.
  • 5.  RE: IAP-275 Power Cords
    Posted Jun 11, 2015 06:31 PM
    look at the 4.1.1.7 release notes for details
  • 6.  RE: IAP-275 Power Cords
    Posted Jun 11, 2015 10:06 PM
    The mesh firmware is in beta and scheduled to be released soon, so I've been told.  Plus the beta firmware is available for download if someone can't wait.
    This doesn't change the neccessity of having a power cord or the cost.
    What does 4.11 release notes say?
  • 7.  RE: IAP-275 Power Cords
    Posted Jun 12, 2015 05:46 PM
    you are correct it will be release sometime later on no eta. it says pretty much what I wrote a couple of posts above. I know mesh works on other models because I've tested it just not on 2xx series.
  • 8.  RE: IAP-275 Power Cords
    Posted Jun 15, 2015 12:47 PM
    From the 6.4.2.6-4.1.1.7 release notes.
