last person joined: 2 hours ago
IAP-277 point-to-point bridge configuration
  • 1.  IAP-277 point-to-point bridge configuration
    Posted Oct 23, 2015 08:59 AM
    I need configuration examples of this solution and can not find, can anyone help me?
  • 2.  RE: IAP-277 point-to-point bridge configuration
    Posted Oct 23, 2015 09:32 AM
    What you need to do is the following:
    - Have both IAPs connected on the same VLAN so they can build a cluster.
    - Once the cluster is build you should be able to disconnect the IAP you are planning to use as the Mesh point.
    - If you only provide power to that IAP (NO NETWORK) then it should be able to build a mesh link automatically if the mesh point is able to build the link with the Mesh portal (IAP with Network connectivity)
  • 3.  RE: IAP-277 point-to-point bridge configuration
    Posted Oct 23, 2015 10:33 AM
    The above is correct. The antenna is wide enough that eye-balling the alignment should be fine. The Instant userguide also has steps on creating an instant mesh cluster.
  • 4.  RE: IAP-277 point-to-point bridge configuration
    Posted Oct 23, 2015 10:39 AM
    I tried but it is not working, sending solution scheme to be set.
    thank you
  • 5.  RE: IAP-277 point-to-point bridge configuration
    Posted Oct 23, 2015 11:04 AM
    ccarrico,
    The only thing not mentioned is that you would have to turn off (disable)  "Extended SSID" in the cluster before you remove the second Mesh AP http://community.arubanetworks.com/t5/Controller-less-WLANs/Aruba-Instant-4-1-Mesh-Configuration/ta-p/214943
