IAP 305 indoor limit session user login captive portal
  • 1.  IAP 305 indoor limit session user login captive portal
    Posted Jun 16, 2021 11:56 AM
    i just buy IAP 305 indoor and i try to setup SSID with captive portal for my company wireless internet so user in my company must input username and password before they can browse to internet,
    i want to ask, can i limit session user login with aruba IAP ? i want to make scenario like this
    1 username for max 2 device access, can i do that with aruba IAP, can you help me?
    dimas dika
  • 2.  RE: IAP 305 indoor limit session user login captive portal
    Posted Jun 16, 2021 07:38 PM
    for that requirement and other workflow, the best is to have ClearPass
  • 3.  RE: IAP 305 indoor limit session user login captive portal
    Posted Jun 17, 2021 01:30 AM
    thanks for your answer sir, any other suggestion sir from opensource product? sorry for my bad english
