last person joined: 9 hours ago
IAP-305-rw access point problems
This thread has been viewed 23 times
  • 1.  IAP-305-rw access point problems
    Posted Mar 21, 2020 06:23 AM
    Eternal reboot of the device I provide a log
    How to solve this problem?
    APBoot 2.4.0.8 (build 64221)
    Built: 2018-03-28 at 20:26:16
    Model: AP-30x
    DRAM: 512 MiB
    Flash: Detected MX25R3235F: total 4 MiB
    NAND: 128 MiB
    PCIE0 link up
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0040 00002 00 00000004 00000000 00000000 00000000
    Power: DC
    Nand Flash error. Status = 0x30,bitflip number is 32
    NAND page read failed. page: 4005 status ffffffb6
    NAND page read failed. page: 4006 status ffffffb6
    NAND page read failed. page: 4045 status ffffffb6
    NAND page read failed. page: 4046 status ffffffb6
    UBI error: vtbl_check: bad CRC at record 44: 0xf116c36b, not 0xf117c36b
    UBI error: process_lvol: both volume tables are corrupted
    UBI error: ubi_init: cannot attach mtd2
    UBI error: ubi_init: UBI error: cannot initialize UBI, error -22
    Volume aos0 not found!
    Creating dynamic volume aos0 of size 0
    UBI error: ubi_create_volume: cannot create volume -1, error -23
    Volume aos1 not found!
    Creating dynamic volume aos1 of size 0
    Volume ubifs not found!
    Creating dynamic volume ubifs of size 0
    Net: eth0
    Radio: qca9990#0, ipq4029#1
    Reset: cold
    FIPS: passed
    Hit <Enter> to stop autoboot: 0
    apboot>
  • 2.  RE: IAP-305-rw access point problems
    Posted Mar 21, 2020 08:38 AM
    That access point needs to be replaced, unfortunately.  That looks like a hardware issue.
  • 3.  RE: IAP-305-rw access point problems
    Posted Mar 21, 2020 11:53 AM
    But how can I restore the firmware? Access is only through apboot (serial console)
  • 4.  RE: IAP-305-rw access point problems
    Posted Mar 21, 2020 12:07 PM
    That looks like a hardware issue.  It doesn't look like it could be fixed with firmware.
  • 5.  RE: IAP-305-rw access point problems
    Posted Jul 27, 2022 02:46 AM
    I encounter this issue just now with AP-207
    Here how I fix
    1. erase first by pressing and hold hole at the bottom for 5s while plugging ethernet poe
    2. follow this and set static ip and upload using latest firmware
    https://acmxguy.wordpress.com/2020/05/06/aruba-iap-ap-boot-image-upgrade/
