IAP 305 RW: virtual controller issue
  • 1.  IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 06:19 AM
    Hello to everyone. I have two AP together in the same group (same configuration, same virtual controller). If I unplug the "master" - the AP that manage the VC web interface - the other AP does not take in charge the virtual controller role.
    I've tried both selecting and/or not the "preferred master" option. Simply if I unplug the master AP the virtual controller becomes unreachable. The Aruba OS version is the 6.5.4.3.
    Is it normal or is this an issue?
  • 2.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 06:37 AM
    Did you set  virtual controller ip address?  That is a separate high availability address that is assumed by the current master.
  • 3.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 06:54 AM
    Hi CJoseph :)
    Yes, during the configuration I've set the VC IP - and after the down of the "master" AP this IP does not more respond.
  • 4.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 07:08 AM
    SSH into the AP that should be up and type "show log system" to see what is going on.
  • 5.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 10:28 AM
    Here I am.
    Using ssh on the survived AP I can see the election of the new master, but I'm unable to access to the VC using the web UI at the VC IP address.
    In this test I used 3 AP, following you can see the log from the new master and the slave one:
    Jan 1 08:19:17 KERNEL(- IP ADDRESS - .221): [ 1170.547199] (08:19:17) !!! Pot-Master ---> Master
    Jan 1 08:19:17 cli[2613]: <341135> <WARN> |AP - IP ADDRESS - .224 cli| Master Changed - new 127.0.0.1 old - IP ADDRESS - .225 current swarm state 3.
    Jan 1 08:19:18 cli[2613]: <341004> <WARN> |AP - IP ADDRESS - .224 cli| Received NTP alert trigger - status is failure, retry - 216, DTLS state - 0
    Jan 1 08:19:18 cli[2613]: <341135> <WARN> |AP - IP ADDRESS - .224 cli| Master Changed - new 127.0.0.1 old - IP ADDRESS - .225 current swarm state 1.
    Jan 1 08:19:18 cli[2613]: <341004> <WARN> |AP - IP ADDRESS - .224 cli| Swarm State Change from Found to Image-ok
    Jan 1 08:19:23 cli[2613]: <341194> <WARN> |AP - IP ADDRESS - .224 cli| Loading configuration, func swarm_timer_handler, line 11596.
    Jan 1 08:19:23 cli[2613]: <341101> <WARN> |AP - IP ADDRESS - .224 cli| Execute command-configure terminal.
    Jan 1 08:19:24 cli[2613]: <341004> <WARN> |AP - IP ADDRESS - .224 cli| Do CLI wlan factory
    Jan 1 08:19:24 cli[2613]: <341004> <WARN> |AP - IP ADDRESS - .224 cli| Swarm State Change from Image-ok to Complete
    Jan 1 08:19:26 cli[2613]: <341097> <WARN> |AP - IP ADDRESS - .224 cli| recv_image_check: mac-xx.xx.xx.xx.xx.xx, version-6.5.4.3-6.5.4.3_61959, ccode_idx-255.
    Jan 1 08:19:26 cli[2613]: <341165> <WARN> |AP - IP ADDRESS - .224 cli| send image match to - IP ADDRESS - .222.
    Jan 1 08:19:31 cli[2613]: <341254> <WARN> |AP - IP ADDRESS - .224 cli| VC add delta configuration id 2 to msg CLI_CONFIG_INIT.
    Jan 1 08:19:31 cli[2613]: <341199> <WARN> |AP - IP ADDRESS - .224 cli| send_config_init: send config to slave - IP ADDRESS - .222, csum 5353, using url 0, auto save disable 0.
    Jan 1 08:19:37 cli[2613]: <341004> <WARN> |AP - IP ADDRESS - .224 cli| provision try.
    Jan 1 08:48:27 cli[4753]: <341135> <WARN> |AP - IP ADDRESS - .222 cli| Master Changed - new - IP ADDRESS - .224 old - IP ADDRESS - .225 current swarm state 3.
    Jan 1 08:48:28 cli[4753]: <341135> <WARN> |AP - IP ADDRESS - .222 cli| Master Changed - new - IP ADDRESS - .224 old - IP ADDRESS - .225 current swarm state 1.
    Jan 1 08:48:29 cli[4753]: <341004> <WARN> |AP - IP ADDRESS - .222 cli| Received NTP alert trigger - status is failure, retry - 541, DTLS state - 0
    Jan 1 08:48:30 cli[4753]: <341135> <WARN> |AP - IP ADDRESS - .222 cli| Master Changed - new - IP ADDRESS - .224 old - IP ADDRESS - .225 current swarm state 1.
    Jan 1 08:48:30 cli[4753]: <341004> <WARN> |AP - IP ADDRESS - .222 cli| Swarm State Change from Found to Image_ok
    Jan 1 08:48:34 cli[4753]: <341004> <WARN> |AP - IP ADDRESS - .222 cli| Received NTP alert trigger - status is failure, retry - 542, DTLS state - 0
    Jan 1 08:48:35 cli[4753]: <341004> <WARN> |AP - IP ADDRESS - .222 cli| restart dhcp helper and dnsmasq!!!
    Jan 1 08:48:35 cli[4753]: <341004> <WARN> |AP - IP ADDRESS - .222 cli| recv_config_init: config isn't changed; skip config and change to sync complete
    Jan 1 08:48:39 cli[4753]: <341004> <WARN> |AP - IP ADDRESS - .222 cli| Received NTP alert trigger - status is failure, retry - 543, DTLS state - 0
  • 6.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 10:42 AM
    From the logs, it also looks like you have no connectivity with the outside world for ntp to sync, and that could cause issues.  Is there a way to fix that and try again?
  • 7.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 11:01 AM
    Usually when I work with this "wifi kit" (1 switch and 2 or more AP) I set a standard configuration working "offline" - see the image below:
  • 8.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 11:57 AM
    Ok,
    On the failover test that you did before, on the new master can you see the other access point(s) by typing "show aps"?
    Can you also do a pcap with wireshark from your laptop when you try to ping the virtual-ip address to see what is being returned?
  • 9.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 01:08 PM
    After shut down the "old" master, on the "new" master I can see only 1 AP (the master itself).
    From the "new" master I can ping with success the VC IP, from my computer (see the previous schema) no.
    I'm not great with Wireshark, what I can see when I start a ping from my computer to the VC IP is a trace from my laptop to the "new" master AP.
  • 10.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 04, 2019 01:11 PM
    The question is, does your windows computer have the ARP entry for the Virtual ip?
    arp -a
  • 11.  RE: IAP 305 RW: virtual controller issue
    Posted Sep 05, 2019 06:46 AM
    No.
    I'm thinking to open a ticket in Aruba Support...
    Thank you CJoseph :)
