IAP-305 US UNII-2 channel support
  • 1.  IAP-305 US UNII-2 channel support
    Posted May 31, 2017 08:09 AM
    Are the IAP-305s supposed to support the UNII-2 channels (52-144) in the US?
    Thanks.
  • 2.  RE: IAP-305 US UNII-2 channel support
    Posted May 31, 2017 08:13 AM
    Yes.  You can run this command on any IAP to find out what channels are supported:  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#CLI_commands/show ap allowed-channels.htm?Highlight=allowed
  • 3.  RE: IAP-305 US UNII-2 channel support
    Posted May 31, 2017 01:42 PM
    I guess my question really was if the AP-305s were ever going to support those channels.
  • 4.  RE: IAP-305 US UNII-2 channel support
    Posted May 31, 2017 02:01 PM
    Do you have an IAP-305 that does not support those channels?
  • 5.  RE: IAP-305 US UNII-2 channel support
    Posted May 31, 2017 02:35 PM
    Yes.
    5/31/2017 14:34:26 PM Target: SCCS-CO-INSIDE-ART Command: show ap allowed-channels
    Allowed Channels for AP Type 305 Country Code US
    PHY Type Allowed Channels
    802.11g (indoor) 1 2 3 4 5 6 7 8 9 10 11
    802.11a (indoor) 36 40 44 48 149 153 157 161 165
    802.11g (outdoor) 1 2 3 4 5 6 7 8 9 10 11
    802.11a (outdoor) 36 40 44 48 149 153 157 161 165
    802.11g 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (indoor) 36-40 44-48 149-153 157-161
    802.11g 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (outdoor) 36-40 44-48 149-153 157-161
    802.11a 80MHz (indoor) 36-48 149-161
    802.11a 80MHz (outdoor) 36-48 149-161
    802.11a 160MHz (indoor) None
    802.11a 160MHz (outdoor) None
    802.11a (DFS) None
  • 6.  RE: IAP-305 US UNII-2 channel support
    Posted May 31, 2017 05:54 PM
    Thank you.  What version is that?
  • 7.  RE: IAP-305 US UNII-2 channel support
    Posted May 31, 2017 07:35 PM
    US (FCC) DFS channels are not yet supported on (I)AP-305.
    They will be enabled in new software once we have obtained the certs.
    This is currently in progress.
