iap -305 virtual controller upgrade
  • 1.  iap -305 virtual controller upgrade
    Posted Dec 08, 2020 05:25 AM
    my certificate for my virtual controller expired in september but i would like to upgrade it from version 6.5.4.8_65873 to the latest but for some reason i cant seem to find the manual file to upgrade it... Can someone please help me with this?
    Niek Vandenabeele
  • 2.  RE: iap -305 virtual controller upgrade
    MVP GURU
    Posted Dec 08, 2020 04:19 PM
    Go on https://asp.arubanetworks.com and download the firmware for IAP 305
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: iap -305 virtual controller upgrade
    Posted Dec 09, 2020 03:58 AM
    hi,
    the problem is that i dont find the firmware there for the iap 305, but do find firmwares for cap ap's. and even if i look not one specific even then for the 305
    Niek Vandenabeele
  • 4.  RE: iap -305 virtual controller upgrade
    MVP EXPERT
    Posted Dec 09, 2020 05:03 AM
    The IAP-305 is an 300 series access point.
    https://asp.arubanetworks.com/downloads;products=Aruba%20Access%20Points;productSeries=Aruba%20Instant%20Campus%20Access%20Points,Aruba%20300%20Series%20Campus%20Access%20Points
    Release Notes here: https://support.hpe.com/hpesc/public/docDisplay?docId=a00102255en_us
    Marcel Koedijk | MVP Expert 2020 | ACMP | ACCP | Ekahau ECSE
  • 5.  RE: iap -305 virtual controller upgrade
    Posted Dec 09, 2020 09:45 AM
    hi,
    the problem is i only find the cap 300 series and not the iap 300 series. the cap 300 series uses a separate controller while the iap ap's the ap itself can be the controller.
    edit: just saw that the series is cap but the model is iap 305... im sorry
    Niek Vandenabeele
