IAP-305 won't join 315-instant
  • 1.  IAP-305 won't join 315-instant
    Posted Mar 13, 2017 03:51 AM
    we recently bought new iap-305 to add to our instant system that runs on 6.5.0.0-4.3.0.0-56428. The 305 has 6.5.1.0.-4.3.1.0-57768 software.
    Where can I find the new software to my existing iap-315 to upgrade?
    In my VC it says "No new version available"
    /Joakim
  • 2.  RE: IAP-305 won't join 315-instant
    MVP EXPERT
    Posted Mar 13, 2017 05:34 AM
    Sometimes there is a delay when posting firmware to the cloud. You can login to the support site and obtain the image from there.
    http://support.arubanetworks.com
  • 3.  RE: IAP-305 won't join 315-instant
    Posted Mar 13, 2017 07:23 AM
    @joasve wrote:
    /Joakim
    Please download the software from the free Limited Lifetime Warranty Site here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/20375/Default.aspx
    The "Check for New Software Button" only works for GA software which only goes up to 4.1.3.4.  The IAP-305 requires 4.3.1.0, however  http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf which is still considered early deployment software.  It is confusing, yes, but download the software and upgrade your entire cluster to 4.3.1.0 and above and it should work.
  • 4.  RE: IAP-305 won't join 315-instant
    Posted Mar 15, 2017 08:27 AM
    Downloaded and upgraded my instant to the same version as the 305 were shipped with. Worked lika charm.
    Thanks for help.  /Joakim
