The firmware version needs to match, so make sure that the 515 is currently running 8.5.0.3 (Draco). Once you upgrade//downgrade the 515, it will pick up in your VC and you will be good to go.
Joseph Mandato
Original Message:
Sent: May 24, 2021 11:08 AM
Subject: IAP 315 and 515 in same cluster
We have just purchased the 515 series and currently have IAP-315 cluster. The cluster is running 8.5.0.3 (hercules). I have powered on the aruba 515 and the power light is solid green but the wifi is blank. The cluster does not show the new access point either. Any ideas where to look next?
Josh McTighe
