IAP 315 and Honeywell Lyric Thermostat 2.4ghz only
  • 1.  IAP 315 and Honeywell Lyric Thermostat 2.4ghz only
    Posted Sep 19, 2020 04:33 PM
    Having an issue where my Honeywell Lyric Thermostat, Model TH6320wf2003, successfully goes through setting up and joining to the wifi24 ssid that is set for 2.4ghz, but after setup when you try to control the thermostat from the app it never synchronizes.  I've got a deebot rumba knock off that works just fine on my 2.4 ghz/5ghz ssid shazzzam, but having issue with this device.
    After setup is complete on the phone and checking the thermostat to change it, I never can because it states syncing with thermostat, but never syncs and gives wifi error. if you click the error the app states status is unavailable, "The thermostat appears to be connected to the network."
    Looking at the dashboard for the clients, it looks like it never gets an ip address, i've tried setting ssid to Virtual Controller managed and Network assigned and it always results in the same result.
    -- 0.0.0.0 00:d0:2d:f2:e7:a2 NOFP wifi24 80:8d:b7:c8:e7:8e 1 GN wifi24 --
    0
    0
    Has anyone help me with this?
    Dan
    Pairing procedure - https://youtu.be/9bQwBZ-pEvE
    -----------------------MY CONFIG----------------------
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.09.19 15:00:03 =~=~=~=~=~=~=~=~=~=~=~=
    sho run
    version 8.6.0.0-8.6.0
    virtual-controller-country US
    virtual-controller-key REMOVED
    name Aruba315
    virtual-controller-ip 10.250.250.4
    terminal-access
    telnet-server
    clock timezone Central-Time -06 00
    clock summer-time CDT recurring second sunday march 02:00 first sunday november 02:00
    rf-band all
    split-5ghz-mode enabled
    allow-new-aps
    allowed-ap removed:c8:e7:8e
    arm
    wide-bands 5ghz
    80mhz-support
    g-channels 1
    min-tx-power 12
    max-tx-power 24
    band-steering-mode prefer-5ghz
    air-time-fairness-mode default-access
    client-aware
    scanning
    client-match
    rf dot11g-radio-profile
    interference-immunity 1
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    hash-mgmt-password
    hash-mgmt-user REMOVED password hash REMOVED
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-SetMeUp
    index 1
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule shazzzam
    index 2
    wlan access-rule wifi24
    index 3
    wlan ssid-profile shazzzam
    enable
    index 0
    type employee
    essid shazzzam
    wpa-passphrase REMOVED
    opmode wpa2-psk-aes
    max-authentication-failures 0
    rf-band all
    captive-portal disable
    dtim-period 1
    broadcast-filter arp
    enforce-dhcp
    multicast-rate-optimization
    dynamic-multicast-optimization
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile wifi24
    enable
    index 1
    type employee
    essid wifi24
    opmode wpa2-psk-aes
    vlan guest
    rf-band 2.4
    allowed-5ghz-radio second-dot11a-radio-only
    dtim-period 1
    enforce-dhcp
    strict-svp
    tspec
    high-efficiency-disable
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-SetMeUp
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-SetMeUp
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    pppoe-uplink-profile
    pppoe-passwd REMOVED
    airgroup
    enable
    multi-swarm
    enable-guest-multicast
    airgroupservice airplay
    enable
    description AirPlay
    airgroupservice airprint
    enable
    description AirPrint
    airgroupservice itunes
    enable
    airgroupservice sharing
    enable
    airgroupservice googlecast
    enable
    airgroupservice AmazonTV
    enable
    airgroupservice "DLNA Media"
    enable
    airgroupservice Sonos
    enable
    id urn:schemas-upnp-org:service:GroupRenderingControl:1
    id urn:schemas-sonos-com:service:Queue:1
    id urn:schemas-upnp-org:service:AVTransport:1
    id urn:schemas-upnp-org:service:RenderingControl:1
    id urn:schemas-tencent-com:service:QPlay:1
    id urn:schemas-upnp-org:service:GroupManagement:1
    id urn:schemas-upnp-org:service:ZoneGroupTopology:1
    id urn:schemas-upnp-org:service:DeviceProperties:1
    id urn:schemas-upnp-org:service:MusicServices:1
    id urn:schemas-upnp-org:service:AlarmClock:1
    id urn:schemas-upnp-org:device:ZonePlayer:1
    id urn:schemas-upnp-org:service:SystemProperties:1
    id urn:schemas-upnp-org:service:ContentDirectory:1
    id urn:schemas-upnp-org:service:ConnectionManager:1
    id urn:smartspeaker-audio:service:SpeakerGroup:1
    id urn:schemas-upnp-org:service:AudioIn:1
    id urn:schemas-upnp-org:device:EmbeddedNetDevice:1
    id urn:schemas-upnp-org:service:EmbeddedNetDeviceControl:1
    id urn:schemas-upnp-org:service:HTControl:1
    airgroupservice Denon
    enable
    id urn:schemas-denon-com:service:ACT:1
    id urn:schemas-denon-com:service:GroupControl:1
    id urn:schemas-denon-com:service:ZoneControl:2
    id urn:schemas-denon-com:device:AiosServices:1
    id urn:schemas-denon-com:device:AiosDevice:1
    id urn:schemas-denon-com:device:ACT-Denon:1
    id urn:schemas-denon-com:service:ErrorHandler:1
    airgroupservice DIAL
    enable
    airgroupservice Spotify
    enable
    id _spotify-connect._tcp
    airgroupservice Netflix
    enable
    id urn:mdx-netflix-com:service:target:3
    airgroupservice companion-link
    enable
    id _companion-link._tcp
    id _homekit._tcp
    id urn:schemas-upnp-org:device:mdxdevice:1
    id urn:schemas-upnp-org:device:InternetGatewayDevice:1
    airgroupservice remotemgmt
    enable
    airgroupservice "DLNA Print"
    enable
    airgroupservice allowall
    enable
    cluster-security
    allow-low-assurance-devices
  • 2.  RE: IAP 315 and Honeywell Lyric Thermostat 2.4ghz only
    Posted Sep 19, 2020 06:57 PM
    Leave it on network assigned, for now.
    Did you go through the troubleshooting steps here?  https://www.honeywellhome.com/us/en/support/why-is-my-thermostat-wifi-not-working/
  • 3.  RE: IAP 315 and Honeywell Lyric Thermostat 2.4ghz only
    Posted Sep 20, 2020 11:14 AM
    So I had looked at the trouble shooting guide.
     https://www.honeywellhome.com/us/en/support/why-is-my-thermostat-wifi-not-working/#networkpairing
    And I thought the encryption I had set was correct, but as a hail mary I tried:
    "WPA-Personal (Both TKIP & AES Encryption)" and it worked!
    Before I had it set to "WPA2-Personal" which I guess is different from "WPA2 AES PSK • WPA2 MIXED PSK." As shown in step 15 of the troubleshooting guide. I also made the pass 8 characters with only letters and numbers.
    15. Make sure your router isn't using any advanced security settings such as after-market firewalls, or connected to any network device, such as a switch or gateway which may have its own security.
    Make sure Wi-Fi network is using one of the following security protocols. Other security protocols are not recommended. • OPEN • WEP PSK • WPA TKIP PSK • WPA2 AES PSK • WPA2 MIXED PSK.
    Hope this helps anyone else that has an iap and honeywell thermostat.  Sad they don't have another firmware to update the security of it. =/
