IAP 315 cant convert to controller 7005
  • 1.  IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 12:03 AM
    Dear All,
    I have 1 controller aruba 7005 with AOS 6.5.0 and 8 iap 315 with arubaInstant OS 6.5.0,
    but these IAP's after I convert to controller, these IAP's detected as airmonitor ap, even if i provisioning to group ap as AP mode,
    after I upgrade firmware controller to 6.5.4, these IAP's detect as down access point, and always loop restart,
    even after I upgrade firmware arubaInstant OS of these IAP's to 6.5.4, the problem still happen, detect as down AP on monitoring controller
    kindly need your advice to troubleshoot it
  • 2.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 12:55 AM
    here's the log from iap when convert process occure :
    apboot> setenv ipaddr 10.10.10.18
    apboot> setenv netmask 255.255.255.0
    apboot> setenv gatewayip 10.10.10.1
    apboot> saveenv
    Saving Environment to Flash...
    Erasing flash...
    Writing to flash... ...............done
    apboot> boot
    Booting OS partition 0
    Checking image @ 0x0
    Invalid image format version: 0x0
    Checking image @ 0x2000000
    Copying image from 0x44000000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.5.0.0-4.3.0.0 (build 56428 / label #56428)
    [    0.000000] Built by p4build@rhodes on 2016-09-12 at 03:03:01 PDT (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) )
    [    0.000000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine: IPQ806X wave-2 board
    [    0.000000] Flash variant: default
    [    0.000000] msm_reserve_memory: 0x44600000, 0x200000
    [    0.000000] Memory policy: ECC disabled, Data cache writealloc
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 123178
    [    0.075601] CPU1: Booted secondary processor
    [    0.102592] clk_tbl_nss - loaded
    [    0.224461] PCI: enabling device 0000:02:00.0 (0140 -> 0143)
    [    0.224648] PCI: enabling device 0000:00:00.0 (0140 -> 0143)
    [    5.987753] get_bootconfig_partition: no dual boot info in shared memory
    [    7.593377] m25p80 spi5.0: found mx25u3235f, expected s25fl512s
    [    9.529459] Found AT97SC3203 on i2c-gpio0
    [    9.584504] no pmic restart interrupt specified
    [   10.224992]
    [   10.224992] Starting Kernel SHA1 KAT ...
    [   10.277132] Completed Kernel SHA1 KAT
    [   10.321899] Starting Kernel HMAC-SHA1 KAT ...Starting Kernel DES KAT ...Completed Kernel DES KAT
    [   10.428241] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [   10.471946]
    [   10.517775] Completed Kernel HMAC-SHA1 KAT
    [   10.567760] Starting Kernel AE??pleted Kernel AESGCM KAT
    Thu Jan  1 00:00:00 PST 1970
    AP-type has_ble_support: ONBOARD.
    Domain Name: instant.arubanetworks.com
    Disabling ipv6 for devices by default
    No panic info available
    Writing /dev/ttyHSL2 into /tmp/ble_port
    Enabling ble_daemon and ble_relay via nanny
    apfcutil: sector CACHE: Cache uninitialized
    apfcutil: sector RAP: Cache uninitialized
    apfcutil: sector FAT: Cache uninitialized
    apfcutil: sector SCRATCH: Cache uninitialized
    Backup ENV.
    apfcutil: sector MESH Prov: Cache uninitialized
    [   15.045673] nss_driver - Turbo Support 1
    [   15.085160] nss_driver - fw of size 186944  bytes copied to load addr: 40800000, nss_id : 1
    [   16.245610] Found isl28022 on i2c-gpio0
    Starting watchdog process...
    [   16.320805] Kernel watchdog refresh ended on core 1.
    [   16.613027] Kernel watchdog refresh ended on core 0.
    Cfg len is 0
    Configuration file is empty, turning on default services...
    extended ssid activate due to no AP config ...
    touching file /tmp/ip_mode_0
    eth1 admin down
    SIOCGIFFLAGS: No such device
    init usb modem ...
    insmod: cannot insert `/lib/slhc.ko': File e[   17.252171] usbcore: registered new interface driver usbserial
    [   17.358856] usbcore: registered new interface driver usbserial_generic
    [   17.436925] USB Serial support registered for generic
    [   17.497219] usbserial: USB Serial Driver core
    xists (-1): File exists
    insmod: cannot insert `/lib/ppp_generic[   17.568978] SCSI subsystem initialized
    .ko': File exists (-1): File exists
    [   17.732895] Initializing USB Mass Storage driver...
    [   17.779006] usbcore: registered new interface driver usb-storage
    [   17.850640] USB Mass Storage support registered.
    No USB Plugged in
    [   37.972164] usbcore: deregistering interface driver usb-storage
    [   38.048266] cdrom: Uniform CD-ROM driver unloaded
    [   38.103655] USB Serial deregistering driver generic
    [   38.157138] usbcore: deregistering interface driver usbserial_generic
    [   38.234083] usbcore: deregistering interface driver usbserial
    [   40.619618] ADDRCONF(NETDEV_UP): bond0: link is not ready
    Ethernet uplink not active yet
    [   46.124523] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    [   46.181880] bond0: 1000Mbps FullDuplexMesh is DISABLED on this device.
    copying bootuplog ...
    [   47.206529] drvlog_mod: module license 'Proprietary' taints kernel.
    [   47.308434] Disabling lock debugging due to kernel taint
    [   47.372008] Settng Jumbo MRU 2000
    [   47.395845] AP xml model 95, num_radios 2 (jiffies 23695)
    [   47.395845] init_asap_mod: installation:0
    [   47.395845] radio 0: band 1 ant 0 max_ssid 16
    [   47.395845] radio 1: band 0 ant 0 max_ssid 16
    [   47.395876] election init: rand=1c HZ=500
    [   47.395876] IAP client match init
    Disabling wpa_supplicant for this paltform
    allow PAPI
    notify asap_mod 3g no present...
    Starting update SBL2 ...
    Prepare update SBL2 ...
    The expected MD5: e337c2ee110ce85a0e5d69059fc774b6
    The SBL file size: 105484
    The /aruba/bin/nor_sbl2.mbn MD5: e337c2ee110ce85a0e5d69059fc774b6
    The MD5 of /aruba/bin/nor_sbl2.mbn is correct
    [   48.686566] Disabling USB power
    [   51.687035] Enabling USB power
    105484+0 records in
    105484+0 records out
    The original SBL2 MD5: e337c2ee110ce85a0e5d69059fc774b6
    CMDLINE_WRITE_ENVIRONMENT arg {NEW_SBL2=1}
    The SBL2 in flash is same to /aruba/bin/nor_sbl2.mbn
    Done.
    apdot1x authentication is not enabled
    Got all network params from APboot env. Skipping DHCP
    Static IP detected. Checking if LACP needs to be configured
    LACP setting not required. AP can ping default gateway
    [   59.418806] ip_time_handler: Got ip and packets on bond0 Started master election 2-0, rand 23
    10.10.10.18 255.255.255.0 10.10.10.1
    Compressing all files in the /etc/httpd directory...
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on pool.ntp.org
    [   73.180099] ath_hal: 0.9.17.1 (AR5416, AR9380, WRITE_EEPROM, 11D)
    [   73.257013] ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    [   73.368322] ath_dfs: Version 2.0.0
    [   73.368322] Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    [   73.506123] ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    [   73.619119] ath_pci:  (Atheros/multi-bss)
    [   73.654607] PCI: enabling device 0000:01:00.0 (0140 -> 0142)
    [   73.722524] ath_pci 0000:01:00.0: ath DEBUG: sc=0xd9e00800
    [   79.473227] Startup Mode-0 set
    [   79.498844] htt_peer_map_timer_init Enter pdev dcd88000 hrtimer dcd8a790
    [   79.577444]
    [   79.577444]  htt_alloc_peer_map_mem : Alloc Success : host q vaddr dc420000 paddr 5d920000
    [   79.694095]
    [   79.694126]  htt_alloc_peer_map_mem : Flush Interval Configured to 256 pkts
    [   79.795313] ol_txrx_pdev_attach: 2500 tx desc's allocated ; range starts from dc0c0000
    [   79.890971]
    [   79.891002] SERIAL NUMBER:  : wifi0
    [   79.891002]
    [   79.967041] wmi_service_ready_event_rx:  WMI UNIFIED SERVICE READY event
    [   80.119650] wmi_ready_event_rx:  WMI UNIFIED READY event
    [   80.171852] target uses HTT version 2.2; host uses 2.2
    [   80.272945] ol_ath_smart_ant_attach: Firmware doest not support Smart Antenna.
    [   80.346954] ol_ath_smart_ant_attach: Hardware doest not support Smart Antenna.
    [   80.433458] dfs_attach: event log disabled by default
    [   80.497032] -1077438292: dev:<wifi0> ic:d9680540 osdev:d9e00810 phy:2wifi0: Base BSSID 34:fc:b9:0d:d0:f0, 16 available BSSID(s) processor ID: 0
    [   80.647985] bond0 address=34:fc:b9:c8:dd:0e
    [   80.698000] br0 address=34:fc:b9:c8:dd:0e
    [   80.745923] wifi0: AP type AP-315, radio 0, max_bssids 16
    [   80.810559] Resetting spectral chainmask to Rx chainmask
    [   80.977538] Resetting spectral chainmask to Rx chainmask
    [   81.028897] Init the PCAP for radio0 offload 1.
    [   81.083161] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
    [   81.150827] ath_pci 0000:03:00.0: ath DEBUG: sc=0xd9e03c00
    [   82.453920] Startup Mode-0 set
    [   82.479818] htt_peer_map_timer_init Enter pdev d9ad8000 hrtimer d9ada790
    [   82.558169]
    [   82.558169]  htt_alloc_peer_map_mem : Alloc Success : host q vaddr dc427000 paddr 5d927000
    [   82.674789]
    [   82.674789]  htt_alloc_peer_map_mem : Flush Interval Configured to 256 pkts
    [   82.776007] ol_txrx_pdev_attach: 2500 tx desc's allocated ; range starts from dc300000
    [   82.871665]
    [   82.871665] SERIAL NUMBER:  : wifi1
    [   82.871665]
    [   82.947735] wmi_service_ready_event_rx:  WMI UNIFIED SERVICE READY event
    [   83.102093] wmi_ready_event_rx:  WMI UNIFIED READY event
    [   83.154295] target uses HTT version 2.2; host uses 2.2
    [   83.160887] ol_ath_smart_ant_attach: Firmware doest not support Smart Antenna.
    [   83.160887] ol_ath_smart_ant_attach: Hardware doest not support Smart Antenna.
    [   83.160918] dfs_attach: event log disabled by default
    [   83.450140] -1077438292: dev:<wifi1> ic:dbf80540 osdev:d9e03c10 phy:2
    [   83.526148] wifi1: Base BSSID 34:fc:b9:0d:d0:e0, 16 available BSSID(s) processor ID: 0
    [   83.620868] bond0 address=34:fc:b9:c8:dd:0e
    [   83.670884] br0 address=34:fc:b9:c8:dd:0e
    [   83.718775] wifi1: AP type AP-315, radio 1, max_bssids 16
    [   83.783411] Resetting spectral chainmask to Rx chainmask
    [   83.846922] Resetting spectral chainmask to Rx chainmask
    [   83.910715] Init the PCAP for radio1 offload 1.
    [   84.019056]  pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
    [   84.094064]  pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
    AP rebooted caused by cold HW reset(power loss)
    shutting down watchdog process (nanny will restart it)...
        <<<<<       Welcome to the Access Point     >>>>>
    Completed SW FIPS KAT test
    [   85.657763] busybox (3328): /proc/3326/oom_adj is deprecated, please use /proc/3326/oom_score_adj instead.
    User: [   87.582786] Kernel watchdog refresh ended on core 1.
    [   87.584786] Kernel watchdog refresh ended on core 0.
    [   96.736113] Disabling USB power
    [   96.761199] Resetting spectral chainmask to Rx chainmask
    [   96.824898] Resetting spectral chainmask to Rx chainmask
    [   99.736676] Enabling USB power
    [   99.760699] Resetting spectral chainmask to Rx chainmask
    [   99.824398] Resetting spectral chainmask to Rx chainmask
    [  103.566791] i am master now
    [  103.587660] (08:01:32) !!! Init ---> Master
    [  103.637644] asap_send_elected_master: sent successfully
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    [  586.267697] Restarting system.
    [  586.291690] Going down for restart now
    APBoot 1.5.5.7 (build 56398)
    Built: 2016-09-08 at 14:21:29
    Model: AP-31x
    DRAM:  491 MB
    SF:    Detected MX25U3235F with page size 64 kB, total 4 MB
    Flash: 4 MB
    NAND:  132 MiB
    PCIE0: link up
    PCIE1: link up
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0046 00002   00 00000004 00000000 00000000 00000000
           00  00  168c  0040 00002   00 00000004 00000000 00000000 00000000
    Power: 802.3af POE
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0
    Radio: qca9983#0, qca9990#1
    Reset: warm
    FIPS:  passed
    Hit <Enter> to stop autoboot:  0
    SHA2 Signature available
    Signer Cert OK
    Policy Cert OK
    RSA signature verified using SHA2.
    [    0.000000]
    [    0.000000] ArubaOS Version 6.5.4.0 (build 60834 / label #60834)
    [    0.000000] Built by p4build@pr-hpn-build05 on 2017-08-04 at 15:40:51 UTC (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) )
    [    0.075663] CPU1: Booted secondary processor
    [    0.102655] clk_tbl_nss - loaded
    [    0.224179] PCI: enabling device 0000:02:00.0 (0140 -> 0143)
    [    0.224398] PCI: enabling device 0000:00:00.0 (0140 -> 0143)
    [    4.969540] m25p80 spi5.0: found mx25u3235f, expected s25fl512s
    [    7.468634] Found AT97SC3203 on i2c-gpio0
    [    7.527803] no pmic restart interrupt specified
    [    8.166916]
    [    8.166916] Starting Kernel SHA1 KAT ...
    [    8.219025] Completed Kernel SHA1 KAT
    [    8.263823] Starting Kernel HMAC-SHA1 KAT ...Starting Kernel DES KAT ...Completed Kernel DES KAT
    [    8.370103] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [    8.413839]
    [    8.459700] Starting Kernel AESGCM KAT ...Completed Kernel HMAC-SHA1 ÿ[    8.586472] Completed Kernel AESGCM KAT
    Domain Name: arubanetworks.com
    Enabling ble_daemon via nanny
    [   12.279256] nss_driver - fw of size 391744  bytes copied to load addr: 40000000, nss_id : 0
    [   12.388503] nss_driver - Turbo Support 1
    [   12.423024] Supported Frequencies - 110Mhz 550Mhz 733Mhz
    [   12.493064] nss_driver - fw of size 190016  bytes copied to load addr: 40800000, nss_id : 1
    [   33.241549] drvlog_mod: module license 'Proprietary' taints kernel.
    [   33.304123] Disabling lock debugging due to kernel taint
    [   33.396688] init_asap_mod: installation:0
    [   33.441299] firewall cpu: core-1
    SBL2 was updated already
    Done.
    [   44.312964] Settng Jumbo MRU 2000
    cat: /sys/class/net/bond0/bonding/mode: No such file or directory
    Bonding mode set to
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Unmounting UBIFS completed.
    [  118.103967] Restarting system.
    Model: AP-31x
    DRAM:  491 MB
    Flash: 4 MB
    NAND:  132 MiB
    PCIE0: link up
    PCIE1: link up
    Power: 802.3af POE
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0
    Reset: warm
    FIPS:  passed
    Signer Cert OK
    Policy Cert OK
    [    0.000000]
    [    0.224523] PCI: enabling device 0000:02:00.0 (0140 -> 0143)
    [    0.224742] PCI: enabling device 0000:00:00.0 (0140 -> 0143)
    [    4.992502] m25p80 spi5.0: found mx25u3235f, expected s25fl512s
    [    7.490690] Found AT97SC3203 on i2c-gpio0
    [    7.550078] no pmic restart interrupt specified
    [    8.189597]
    [    8.189597] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [    8.268853] Starting Kernel HMAC-SHA1 KAT ...Starting Kernel DES KAT ...Completed Kernel DES KAT
    [    8.375164] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [    8.418869]
    [    8.464667] Completed Kernel HMAC-SHA1 KAT
    [    8.514651] Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
    [   12.210028] nss_driver - fw of size 391744  bytes copied to load addr: 40000000, nss_id : 0
    [   12.319150] nss_driver - Turbo Support 1
    [   12.353670] Supported Frequencies - 110Mhz 550Mhz 733Mhz
    [   12.423680] nss_driver - fw of size 190016  bytes copied to load addr: 40800000, nss_id : 1
    [   33.148890] drvlog_mod: module license 'Proprietary' taints kernel.
    [   33.211433] Disabling lock debugging due to kernel taint
    [   33.401062] init_asap_mod: installation:0
    [   33.446641] firewall cpu: core-1
    Done.
    [   44.265010] Settng Jumbo MRU 2000
    Bonding mode set to
    Done. Master is
    [  118.109996] Restarting system.
    Model: AP-31x
    DRAM:  491 MB
    Flash: 4 MB
    NAND:  132 MiB
    PCIE0: link up
    PCIE1: link up
    Power: 802.3af POE
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0
    Reset: warm
    FIPS:  passed
  • 3.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 01:07 AM
    oh, one more,
    at first initial set up of iap, i dont see my country code I usually use, SG and ID, and my controller country code is SG,
    the information from IAP is if I dont see my country code, I should try to upgrade to latest firmware, but even I upgrade to 6.5.4.0 which mean latest firmware, I still dont see country code SG or ID
  • 4.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 03:32 AM
    Did you do the conversion process on GUI?
    In the logs it seems it cant find the master
    "Done. Master is"
    Maybe try with "setenv master IP"?
  • 5.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 03:43 AM
    i just type like this :
    setenv ipaddr 10.10.10.1x
    should i put masterip ?
  • 6.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 03:45 AM
  • 7.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 09:03 AM
    thanks for the response
    how can i apply drt to these IAP sir ?
  • 8.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 10:40 AM
    For Instant AP, the DRT is built into the firmware. However, as you want to convert to controller AP, you will need to have the DRT or proper regulatory support from the installed firmware, only there.
    When you convert an IAP to AP (Controller), all configuration is lost, and everything is configured and controlled by the controller.
    As you mentioned that the APs come up as Air Monitor (I assumed on the controller), that may be because the controller firmware does not support your APs in the firmware and DRT upgrade may solve that and get the APs into normal radio mode.
    Follow cjoseph's advice and check why the AP does not become active on the controller.
  • 9.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 03:44 AM
    The master discovery after the conversion is not working properly:
    Bonding mode set to
    Done. Master is
    I would advise you first, until things work, to have the APs in the same VLAN as the controller, and use DHCP. From the information that you provide (just from the AP side), it is difficult to make up what is setup incorrectly.
    When APs go into 'Airmonitor' it is likely that there is a regulatory domain issue, for example US type APs on a Rest-of-World controller. Or the controller firmware does not support your AP yet.
    Sometimes this can be fixed with a DRT (Downloadable Regulatory Table, or something like that), which can be found on the Aruba support site.
    The support for AP-315 in Singapore (SG) was added in DRT 1.0_57776
    AP-315 for Indonesia (ID): DRT 1.0_58226
    To check on your controller:
    (md-7005-01) #show ap regulatory
    Regulatory Version    :1.0_60744
    (md-7005-01) #show ap allowed-channels country-code ID ap-type AP-315
    Allowed Channels for AP Type AP-315 Country Code "ID" Country "Indonesia"
    PHY Type                  Allowed Channels
    802.11g (indoor)          1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor)          149 153 157 161
    802.11g (outdoor)         1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor)         149 153 157 161
    802.11g 40MHz (indoor)    None
    802.11a 40MHz (indoor)    None
    802.11g 40MHz (outdoor)   None
    802.11a 40MHz (outdoor)   None
    802.11a 80MHz (indoor)    None
    802.11a 80MHz (outdoor)   None
    802.11a 160MHz (indoor)   None
    802.11a 160MHz (outdoor)  None
    802.11a (DFS)             None
    (md-7005-01) #show ap allowed-channels country-code SG ap-type AP-315
    Allowed Channels for AP Type AP-315 Country Code "SG" Country "Singapore"
    802.11a (indoor)          36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    802.11a (outdoor)         36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    802.11g 40MHz (indoor)    1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (indoor)    36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
    802.11g 40MHz (outdoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (outdoor)   36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
    802.11a 80MHz (indoor)    36-48 52-64 100-112 116-128 149-161
    802.11a 80MHz (outdoor)   36-48 52-64 100-112 116-128 149-161
    802.11a 160MHz (indoor)   36-64 100-128
    802.11a 160MHz (outdoor)  36-64 100-128
    802.11a (DFS)             52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    Please work with your Aruba partner or Aruba SE if you keep having issues for advice.
  • 10.  RE: IAP 315 cant convert to controller 7005
    Posted Sep 04, 2017 09:14 AM
    @Hudaya wrote:
    Dear All,
    While the APs are rebooting, type "show log system 50" on the Aruba Controller to see if it says why the APS are rebooting.  You should have a controller with a ROW designation.  Also, type "show ap database" to see if those down APS have a flag.
