IAP 315 config status verifing when no changes have been made
  • 1.  IAP 315 config status verifing when no changes have been made
    Posted Aug 12, 2019 03:51 AM
    Can someone tell me why some VC/AP's config status changeds from good to verifing in Airwave when no changes have been made to the config template and how to stop it from happening again please?
    So far the only way to fix the issue is to delete the VC and AP's from Airwave and wait for them to connect to Airwave again.  This is only a short term solution because it'll either happen to the same VC/AP's or other ones in the same group.
    Sean
