last person joined: 3 hours ago
IAP 315 Portal to Point - Link lost when Uplink Enabled
  • 1.  IAP 315 Portal to Point - Link lost when Uplink Enabled
    Posted Mar 10, 2020 09:00 AM
    I am trying to configure a Point to point link over Wifi wich a mesh of IAP 315 as portal devices that are wired and one IAP 315 as point device wired with an wired device.
    Switch -----> IAP 315 (1) Mesh )))))          (((((( IAP 315 (2) Point ---->POE Switch (manageble but not configured) ---> Device
    I configured all like described in the Forum:
    - Extended SSID Disabled, all my devices are Portals included the IAP that should be moved to a different location an connect over WIFI.
    - Restart all devices.
    - Plug the Point IAP to his final location
    - Enable Eth0- Bridging
    After doing this, the device get shown in the APs list for a few seconds after it, it desapears and I have no link anymore.
    Notes:
    The IAP 315 (2) has an static IP, same network as IAP 315 (1) DHCP
    In the Cluster, under System --> Uplink: WIFI SSID is not configured, as default.
    Wired port:
    VLAN is as:
    Trunk
    Native VLAN 1
    Permited VLANs ALL
    Security all deactivated
    Edited:
    Wired --> Edit Wired Network: Admin Status is "DOWN"
    This Option enables the Ethernet Port 0 ? After setting it as Bridge?
    Someone have an idea why I lost my link after enabling Eth0-Bridging?
    The switch shows POE connection but no link, the IP is not pinable.
  • 2.  RE: IAP 315 Portal to Point - Link lost when Uplink Enabled
    Posted Mar 13, 2020 06:43 PM
    check your setup again this guide which is very similar to what you are trying to do.
    https://community.arubanetworks.com/t5/Controllerless-Networks/Wireless-Mesh-enhancements-with-Instant-8-4/td-p/536790
    regards
    Ariya
