IAP-315 ZTP with Airwave help
  • 1.  IAP-315 ZTP with Airwave help
    Posted Sep 30, 2021 11:50 AM
    Hello
    Have been wanting to do this for while and finally started messing with it.
    So far I have the DHCP working, in the sense that the IAP will boot, get an ip and reach out to the Airwave server.
    I can add it to the group i want and it will upgrade if it needs it and reboot, but then it will not pull the configs down. it show mismatch with the entire config listed. if i hit the "Apply" button it will apply the config and everything work but then after about 5 minutes the config is cleared from the device and it shows mismatch again.
    Andrew Miller
