IAP-325 and Asus PCE-AC88 cannot connect with 4ss
  • 1.  IAP-325 and Asus PCE-AC88 cannot connect with 4ss
    Posted Jan 17, 2019 01:30 AM
    I checked Iap-325 can support up to 4ss 1750mbps, so I just bought a pci-e wireless adapter yesterday (Asus PCE-AC88) which support 4ss with up to 2133mbps.
    When connecting to ap on Windows 10, it will disconnect within 30 seconds and re-connect, and repeat again.
    I checked some documents and set "vht-supported-mcs-map" to "9,9,9,-" and re-connect problem solved but it only show 1300mbps and 3ss in "show ap association".
    I have also tried to disable mu-mino but nothing changed.
    Is that Iap-325 not support 4ss or it need to run with specific configuration?
    PCE-AC88 with vht-supported-mcs-map "9,9,9,9"
    PCE-AC88 with vht-supported-mcs-map "9,9,9,-"
    Thank you!
    Sam
