IAP-325 and Multicast Issue
  • 1.  IAP-325 and Multicast Issue
    Posted Mar 18, 2016 09:32 PM
    I believe I have a configuration issue as I've reduced the network complexity down to 5 total devices and the problem is present.
    Printer connected via WiFi to IAP325
    IAP325 connected to 4 port switch
    iPhone attempting to find Airport Printer
    DHCP Server
    Wifi Connected Roku Player
    my iPhone cannot find the airprint printer on the same network
    the youtube app on my iphone cannot find the youtube application running on the Roku.
    I suspect there is a multicast issue - so I turned the "Broadcast Filtering" option to disabled and no change in luck.
    From what I read, I don't think I need ot enable AirGroup under Services but perhaps I do?
  • 2.  RE: IAP-325 and Multicast Issue
    Posted Mar 18, 2016 09:35 PM
    What version of instade code are you running?
    Are both devices on the same vlan?
    Do you have the SSID set to unrestricted?
  • 3.  RE: IAP-325 and Multicast Issue
    Posted Mar 18, 2016 09:37 PM
    What version of instade code are you running?  Code is:  6.4.4.3-4.2.2.0_53034
    Are both devices on the same vlan?   Yes
    Do you have the SSID set to unrestricted?  Yes
    Interestingly I just tried enabling every drop down in AirGroup and everything is working.  I was under the impression that was not needed in a simple setup such as mine.
