IAP 325 controller base always need to reset ( AP hang )
  • 1.  IAP 325 controller base always need to reset ( AP hang )
    Posted Jul 09, 2019 01:54 AM
    hii.. already deploy IAP 325 controller base at small airport
    33 units Ap and 1 controller
     only 4 unit at departure area always need to reset ..
    the other AP no problem ..
    distance betwen AP at departure area 35 meter
    RF for  radio 2.4 and 5  set to default
    any idea  ?
    tq
  • 2.  RE: IAP 325 controller base always need to reset ( AP hang )
    MVP EXPERT
    Posted Jul 09, 2019 03:14 AM
    Do you have the tech-support from the AP which are having the issue? What firmware version are you running? Has this just started happening? Has there been any changes to your environment?
  • 3.  RE: IAP 325 controller base always need to reset ( AP hang )
    Posted Jul 09, 2019 03:55 AM
    hii craig..FYI
    - no tech support, my IT vendor disappeared
    - current controller version  = 6.5.1.4
    - after 3 month installation
    tq
