IAP-325 or dual eth IAPs wire speed
  • 1.  IAP-325 or dual eth IAPs wire speed
    Posted Nov 15, 2018 06:44 PM
    Has anyone tested the wire speed on any of the dual ethernet IAPs with iperf3 server and client on each of the port (essentially making the IAP a switch/hub)?
    I have an open ticket with an IAP-325 and was told that the throughput result of 3xxMbps is expected. I don't quite understand why the result is so low, when both ethernet ports are negotiated at 1G full duplex.
    Thanks in advance.
  • 2.  RE: IAP-325 or dual eth IAPs wire speed
    Posted Nov 15, 2018 08:18 PM
    I have not tested, but I imagine that this is because of packets being processed by CPU and passed between the two ports i.e. there isn't actually a 2-port ASIC in there like a switch would have.
  • 3.  RE: IAP-325 or dual eth IAPs wire speed
    Posted Nov 15, 2018 10:49 PM
    Thanks.
    Would that mean if the two ports where to LACP, as it is processed by a single CPU it will not achieve a higher throughput versus a single port?
  • 4.  RE: IAP-325 or dual eth IAPs wire speed
    Posted Nov 18, 2018 05:00 PM
    Good question. Hopefully an Aruba staff member can respond.
  • 5.  RE: IAP-325 or dual eth IAPs wire speed
    Posted Nov 25, 2018 05:15 PM
    Bumping this question to get attention of tech. Is it true that it is only a single CPU serving both ethernet ports? If so then what is the actual use of a LACP here?
    Thanks.
