IAP-325 with IAP-105 Airwave managed same cluster
  • 1.  IAP-325 with IAP-105 Airwave managed same cluster
    Posted Jul 22, 2015 11:12 AM
    Hello, I have a network of IAP-105 running with AirWave management enabled. They want to add some IAP-325 in the same cluster. I know that they have to run the same firmware but I could not find the necessary firmware on the SSO site.
    Can you provide the firmware revision please ?
    Do you see any drawback mixing IAP-325 with IAP-105 and Airwave config enabled ?
    Thank you
    #AP325
    #AP-300
  • 2.  RE: IAP-325 with IAP-105 Airwave managed same cluster
    IAP-320s are not yet publicly available. Please contact your local Aruba team.
  • 3.  RE: IAP-325 with IAP-105 Airwave managed same cluster
    Posted Oct 20, 2015 04:37 PM
    The IAP 320s are already released?
