IAP-325 won't join cluster
  • 1.  IAP-325 won't join cluster
    Posted Dec 05, 2016 09:24 AM
    Hi, I have 2x IAP-325 with one configured as Master VC and another that won't join the cluster. When I examine the log output of the slave AP it says "Fall into standalone mode because of asap msg" - is this relevant?
    Both APs are on same version of code - v6.5 and are on same subnet. Auto-join is enabled on both APs and country codes are the same. They were previously on firmware 6.4 and wouldn't join so tried upgrading to 6.5 but still no success.
    Anything I should look for in the logs?
    Cheers,
    Graeme
  • 2.  RE: IAP-325 won't join cluster
    Posted Mar 02, 2019 03:06 AM
    graeme-muir ...Same issue the salve AP is unable to broadcast the SSID and is not able to broadcast SSID.
