hi,
My 335 takes 3 to 5 minutes to startup, so i decided to check terminal and got this readout:
Image is signed; verifying checksum... passed
SHA2 Signature available
Signer Cert OK
Policy Cert OK
RSA signature verified using SHA2.
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 8.8.0.0-8.8.0.0 (build 79697 / label #79697)
[ 0.000000] Built by p4build@pr-hpn-build07 on 2021-03-27 at 06:04:59 UTC (gcc version 4.8.1)
[ 28.909848] INFO: rcu_sched self-detected stall on CPU { 1} (t=21000 jiffies g=4294967157 c=4294967156 q=43)
[ 56.010849] BUG: soft lockup - CPU#1 stuck for 23s! [swapper/0:1]
[ 56.083774] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.12.19-rt30 #79697
[ 56.165028] task: df4a8000 ti: df4b0000
task.ti: df4b0000
[ 84.048256] UBI warning: ubi_calculate_reserved: number of bad PEBs (7) is above the expected limit (6), not reserving any PEBs for bad PEB handling, will use available PEBs (if any)
[ 84.316237]
Should i be worried about CPU lockups and bad PEBs being over the limit?
Vytautas vt
