Hi Guy,
My IAP 335 client queue 116 can't connect.
Model 335 supported 150+ of active client right?
Why on my 335 still only 115 client?
All client are Apple devices.
Best regards,
That is far too many clients for a single AP. Surely it must be a degraded service? There is a Max Client Limit threshold under the WLAN Settings when you edit the WLAN.Why do you have that amount of clients on a single AP?
I didn't know clients more than 100.
And on presented slide from vendor told me model 335 can be Serv client more than 150+.
Finally model 335 can Serv only 115 client right?
The datasheet advises the below. It is strongly recommended that you do not run that amount of clients per AP as it will provide an extreme poor performance.
Support for up to 256 associated client devices per radio, and up to 16 BSSIDs per radio
Do you mean iap335 can Serv only 115 active client on a single AP right?
Or, If I have a single AP model 335.
How to set configuration on instant gui allowed client more than 115?
Thanks.
http://www.arubanetworks.com/techdocs/Instant_430_WebHelp/InstantWebHelp.htm#UG_files/WLAN_SSID_conf/ConfiguringWLANPro.htm?Highlight=max%20clients%20threshold
What do you currently have the max clients threshold set to for the WLAN?
(Instant AP)(SSID Profile <name>)# max-clients-threshold <number-of-clients>
thank you.
