IAP 4.0.0.1 Error
  • 1.  IAP 4.0.0.1 Error
    Posted Dec 06, 2013 10:50 AM
    Just upgraded to the latest firmware version, getting a config verion not found in command model list error.  Any quick fixes for this?
  • 2.  RE: IAP 4.0.0.1 Error
    Posted Dec 06, 2013 11:14 AM
    What IAP model are you using ?
  • 3.  RE: IAP 4.0.0.1 Error
    Posted Dec 06, 2013 11:23 AM
    IAP 105
  • 4.  RE: IAP 4.0.0.1 Error
    Posted Dec 06, 2013 11:25 AM
    Make sure you are trying to install the following version : ArubaInstant_Orion_6.3.1.1-4.0.0.1_41049
  • 5.  RE: IAP 4.0.0.1 Error
    Posted Dec 06, 2013 11:26 AM
    Yes that was the version I installed.
  • 6.  RE: IAP 4.0.0.1 Error
    Posted Dec 06, 2013 11:32 AM
    Are you using AirWave or Central?
    Are all the IAPs in the cluster IAP-105 or is this a mixed cluster?
    Are these all -US?  Country code designations just changed in this release.
    You may want to open a case with TAC for diagnosis. Be sure to grab the output of "show tech support" to post to the case notes.
    I just looked for any open bug matches and did not find anything.
  • 7.  RE: IAP 4.0.0.1 Error
    Posted Dec 06, 2013 11:45 AM
    I have used the Instant Config on Airwave.  Have all the AP's in the same group but they are spread out at different facilities.  So basically there is 2 seperat VC with static ip's that are point back to Airwave to a community string.
  • 8.  RE: IAP 4.0.0.1 Error
    Posted Dec 06, 2013 12:37 PM
    Ah...............that is a screen capture from AirWave.  From your post it sounded like this was on the IAP.
    AirWave does not yet have parity with IAP 4.x so I'm sure there is something in the new IAP config that AirWave does not know what to do with.  AirWave should be able to show you what the mismatch is.
