IAP 505 cluster AP checksum error
This thread has been viewed 28 times
  • 1.  IAP 505 cluster AP checksum error
    Posted Aug 13, 2020 10:00 AM
    hello,
    I just deployed a brand new IAP-505 cluster (controlerless) in version 8.6.0.4 but it is unstable... I explain myself:
     - every AP that is connected on a different switch than the one where is the virtual controler has a log message: AP checksum error
     - when I modify the configuration, the Wifi is completely unstable for about 5 min.
    here is a quick output of # show log system from the VC
    Aug 13 15:56:56 cli[4664]: <341132> <WARN> |AP AP-CH1-04@10.6.12.148 cli| Check sum mismatch for AP-10.6.12.166, slave 28729 vs master 1259, error_cnt 1, recover_sent 6.
    Aug 13 15:56:56 cli[4664]: <341132> <WARN> |AP AP-CH1-04@10.6.12.148 cli| Check sum mismatch for AP-10.6.12.160, slave 28729 vs master 1259, error_cnt 7, recover_sent 6.
    Aug 13 15:56:57 cli[4664]: <341132> <WARN> |AP AP-CH1-04@10.6.12.148 cli| Check sum mismatch for AP-10.6.12.152, slave 28729 vs master 1259, error_cnt 6, recover_sent 6.
    the cluster is managed by airwave.
    the switches are also Aruba and the network topology is simple ( a simple star). Spanning tree is enable (MST)
    I'm used to deploy IAP-305 and I never had that kind of issue.
    Do you have any idea?
    Thank you for your help
    Clement
  • 2.  RE: IAP 505 cluster AP checksum error
    Posted Aug 14, 2020 04:01 AM
    From what you explain: APs on the same switch as the VC are fine, those on a different switch get out of sync, suggest to me there is something between the switches.
    Do you see anything in the switch logs, like spanning-tree block?
    Have not seen this recently, so if there is no further response please reach out to Aruba Support and have them look at it.
  • 3.  RE: IAP 505 cluster AP checksum error
    Posted Apr 26, 2021 07:54 AM
    Hi Clement,
    Did you find a resolution to this?  I'm seeing similar issues with IAP-515 instant clusters on AOS 8.6.0.4
    Many thanks
    Ronnie
    Ronnie Guthrie
