IAP 515 and 315 cluster not syncing
  • 1.  IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 12:12 AM
    I would like to ask for advise if someone has encounter similar issue as mine:
      1. i have 2 IAP(IAP 515 and IAP 315) running on Firmware version 8.5.0.1 with DRT ver 1.0_72057
      2. When I turn on the IAP 515 and create ssid, setup VC, client to connect to SSID, etc no issue(as a single IAP running on the vlan). Same apply to the IAP 315.
    3. When I power on both IAP on the same VLAN, only the master is showing up. The second IAP(slave either 515 or 315) can be ping and connected via ssh but its not showing in the cluster.
    Hope you can help to resolve my issue. Thanks.
  • 2.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 03:36 AM
    The 315 and 515 might not automatically synchronize their versions of Instant. I would manually upgrade the 315 cluster/AP to match the version of the 515 before adding the 515 to the cluster.
  • 3.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 03:48 AM
    Hi cjoseph,
                    the 2 AP have the same firmware version. I tried adding manually its MAC address to the master(cluster) also not working(disabled Auto Join).
  • 4.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 03:53 AM
    You should boot one IAP up first. After five minutes add the second IAP to the cluster. Please post the output of "show swarm" for both devices after 10 minutes so we can see what is going on.
  • 5.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 04:50 AM
    Hi cjoseph,
               Please refer below:master.png
  • 6.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 05:40 AM
    When you execute "show APs" on either IAP, do you see two access points?
  • 7.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 05:58 AM
    Hi cjoseph,
                 please refer results:
  • 8.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 06:03 AM
    Please reboot both access points.  I see that one has been up for 17 hours ..
  • 9.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 06:38 AM
    Hi cjoseph,
           I have rebooted both of the IAP's but still the same results.
  • 10.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 06:48 AM
    Okay.
    When you type "show version" on both access points, do they have the exact version?
    "show log system" on each access point might reveal a specific issue that each access point might have synchronizing with the other.
  • 11.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 09:53 AM
    Hi cjosepch,
    I noticed something, the clock of the IAP 515 keeps on going back to default everytime I reboot. I tried to power on the IAP 315(master AP) but still the same. Could this be the culprit? Im not sure if this be resolve by upgrading or downgrading the current IAP firmware :(
  • 12.  RE: IAP 515 and 315 cluster not syncing
    Posted Sep 28, 2019 02:49 PM
    It could be a problem.  The AP should really be able to access the internet to set the clock properly.
    There is no battery in the AP to keep the time, so the AP will set its clock from scratch every time it is booted up from an internal NTP source, so the internet should have port 123 allowed so that it can set its clock.
  • 13.  RE: IAP 515 and 315 cluster not syncing
    Posted Oct 08, 2019 04:18 AM
    Hi cjoseph,
             AP is able to access the internet. DNS, NTP are set but still not working. I have log the case to Aruba support, checked but still not working. Last move will be RMA.
  • 14.  RE: IAP 515 and 315 cluster not syncing
    Posted Oct 18, 2019 06:55 PM
    Any update after working with TAC?
  • 15.  RE: IAP 515 and 315 cluster not syncing
    Posted Oct 18, 2019 09:18 PM
    Check if one of them is set to standalone?  I don't know what the boot_env would be for that off the top of my head.
