IAP-515 and IAP-535 Clustering
  • 1.  IAP-515 and IAP-535 Clustering
    Posted Mar 09, 2020 06:34 PM
    Hi All,
    This is my first post, and i would like to ask if it is possible to cluster IAP515 and 535 with the same version 8.5.0.5?. Airwave is already integrated and Clearpass as well.
  • 2.  RE: IAP-515 and IAP-535 Clustering
    Posted Mar 09, 2020 06:58 PM
    yes Instant version 8.5.x supports the AP-535 and AP-555s as well.
    So you should be fine.
    Make sure, your  Airwave has the firmware 8.5.0.5 for your AP-535 incase the AP-535 that you'll be adding does not have that firmware.
