IAP 515 cannot join IAP-207 VC Cluster
  • 1.  IAP 515 cannot join IAP-207 VC Cluster
    Posted Nov 24, 2020 05:07 AM
    Hi All,
    I got problem for my IAP 515 cannot join the cluster of IAP-207
    some troubleshoot that I already did :
    - all iap in same VLAN and segment (515 IP : 192.168.88.248, 207 IP :192.168.88.251)
    - in system>Auto Join Mode is enabled
    - IAP Version both are same, i use 8.6.0.6
    - already tried to make the 207 the prefered VC-> nothing happen
    any clue for this?
    Djoko Setyanto
  • 2.  RE: IAP 515 cannot join IAP-207 VC Cluster
    MVP GURU
    Posted Nov 24, 2020 08:28 AM
    What does it look like when both are up and running? Are they showing up as separate clusters, or is one getting stuck?
    Do either of them get managed via Central, or have at any point?
    Dustin Burns
  • 3.  RE: IAP 515 cannot join IAP-207 VC Cluster
    Posted Nov 24, 2020 08:34 AM
    They showing up in separated cluster, I already remove them from the central. 515 is the new AP in cluster
    Btw, just now it already solved
    I try to reset factory for the IAP-207 again,while the 515 still have some wlan config,
    After the factory reset the IAP-207 can join the cluster.
    Still don't understand why 515 don't want to join the 207 vc cluster
    Thank you for all your help
    Disclaimer: Privileged/Confidential information may be contained in this message and may be subject to legal privilege. If you are not the intended recipient (or responsible for delivery of the message to such person), you may not use, copy, distribute or deliver to anyone this message. All reasonable precautions have been taken to ensure no viruses are present in this e-mail. The views, opinions, conclusions and other information expressed in this electronic mail are not given or endorsed by the company unless otherwise indicated by an authorized representative independent of this message.
