iap 6.2 guest ssid - clients get redierct loop
  • 1.  iap 6.2 guest ssid - clients get redierct loop
    Posted Sep 25, 2013 12:57 PM
    I have a new IAP105, upgraded to latest firmware 6.2.1.0-3.4.0.1_39461.  I've configured a guest ssid using the internal captive portal.  clients get an IP from the controller, but opening a browser results in a redirect loop.  Currently set as basic as possible - IP address is VC-assigned, no access restrictions.  Any thoughts on resolving this issue?
  • 2.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Sep 25, 2013 02:01 PM
    check that DNS is working.  non working DNS has caused this problem for me in the past.
  • 3.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Sep 25, 2013 02:32 PM
    Interesting... I am using my provider's DNS.  Wonder if it tries to do dns lookup using the native IP of the client rather than the VC's IP address.
    Another interesting bit is that if I change the URL on the client from https://securelogin.arubanetworks.com to http://securelogin.arubanetworks.com, it goes to the captive portal without any problems.  The cert on the AP seems to be good, but this is starting to seem like a cert issue of some sort.
    John
  • 4.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Sep 25, 2013 05:37 PM
    hmmm.. more interesting stuff - works perfectly on an ipad, so seems to be windows-related at this point.
  • 5.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Sep 25, 2013 05:45 PM
    windows 7 seems good also.  narrowing this down to a windows xp issue.
  • 6.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Oct 05, 2013 09:28 PM
    John, I've seen this occur with certain configurations, but generally only eith external captive portals.  Out of curiosity, is auto whitelist enabled?
  • 7.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Oct 07, 2013 02:27 PM
    This is probably related the the homepage the user has set in their browser.  A lot of properties such as Facebook and Google automatically redirect users to the HTTPS version.
    Assuming the client has their browser homepage set to google.com or facebook.com, the following would happen:
    - client associates to the network
    - client launches browser to an HTTP page which returns a 302 redirect to its HTTPS equivalent (example: http://google.com and http://facebook.com, which now redirects all users to https://google.com and https://facebook.com by default).
    - client reaches the http://google.com servers (due to auto whitelisting), which returns a 302 redirect to https://google.com.
    - client follows the 302 and attempts to access https://google.com.
    - IAP intercepts the connection, spoofs the SSL certificate and redirects client to http://google.com.  This "spoof SSL and redirect to non-SSL" behavior appears to be expected, and is how you intercept outbound HTTPS requests for portaling.
    [Process repeats until the browser errors out due to redirect loop]
    Disable auto whitelisting should prevent the redirect loop with the side affect of the user receiving cert mismatch errors.  I suppose you might be able to whitelist the HTTPS version of these sites but have not tested it.
  • 8.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Oct 07, 2013 04:13 PM
    There are some forthcoming enhancements planned for a future release of IAP code that will bring some modification to how IAP handles external captive-portal and https sites. Stay tuned for the announcement!
  • 9.  RE: iap 6.2 guest ssid - clients get redierct loop
    Posted Oct 08, 2013 09:23 AM
    I'll take a look at the auto-whitelist feature.  Odd that this just seems to happen with WinXP devices.  Apple IOS and Windows 7 get redirected correctly to https://securelogin.arubanetworks.com.  On WinXP, if I use Firefox, I can manually change the redirect from https to http and then the captive portal comes up and I can enter login credentials.  IE and Chrome don't display the redirected URL.
    John
