iap 6.2 guest ssid - clients get redirect loop
  • 1.  iap 6.2 guest ssid - clients get redirect loop
    Posted Aug 10, 2019 06:36 AM
    I have a new IAP105, upgraded to latest firmware 6.2.1.0-3.4.0.1_39461.  I've configured a guest SSID using the internal captive portal.  clients get an IP from the controller, but opening browser results in a redirect loop.  Currently set as basic as possible - IP address is VC-assigned, no access restrictions.  Any thoughts on resolving this issue?
    thanks
    iosman
  • 2.  RE: iap 6.2 guest ssid - clients get redirect loop
    MVP EXPERT
    Posted Aug 12, 2019 04:21 AM
    Have you replaced the default certificate? The one shipped with that version was revoked and therefor will cause issues with browsers.
    https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
    *Edit - Make sure your clients have a valid and working DNS server too.
  • 3.  RE: iap 6.2 guest ssid - clients get redirect loop
    Posted Aug 12, 2019 08:23 AM
    @Craig Syme wrote:
    Have you replaced the default certificate? The one shipped with that version was revoked and therefor will cause issues with browsers. 0xc004f074
    thanks my issue has been fixed.
  • 4.  RE: iap 6.2 guest ssid - clients get redirect loop
    MVP EXPERT
    Posted Aug 12, 2019 08:28 AM
    Glad to hear it!
