IAP 6.3 WPA2-Enterprise with Portal
  • 1.  IAP 6.3 WPA2-Enterprise with Portal
    Posted Jun 25, 2014 05:37 AM
    Hi!
    Since 6.2 it should be possible to add a captive portal after 802.1x auth, see http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Chapter11%20Authentication/ConfAccessRuleCPl.htm
    Doing this, the CP is displayed (with just terms & conditions "Accept" - which is, what we want), but the CP is displayed again and again. Sure, because i stay inside this Role which enforces Portal Page again and again.
    Do i need to assign another role based on the new CP-"authentication"? But how to do this?
    Something like
    set-role ???? contains accepted "rule-allow-all"
    Any suggestions?
    Kind Regards
    Folke
  • 2.  RE: IAP 6.3 WPA2-Enterprise with Portal
    Posted Jun 25, 2014 06:23 AM
    You would need a policy engine (like Clearpass) to be able to track whether the user has accepted the terms before.
  • 3.  RE: IAP 6.3 WPA2-Enterprise with Portal
    Posted Jun 25, 2014 06:30 AM
    Hi Tim,
    thanks for your very fast response.
    But what's the sense that Instant supports internal splash screen as Role-Action ("Enforce Captive Portal") when it's not usable?
    Is there a way to examine all values usable for role assignment?
    Kind Regards from Munich
    Folke
  • 4.  RE: IAP 6.3 WPA2-Enterprise with Portal
    Posted Jun 25, 2014 08:07 AM
    Maybe I misunderstood your question.
    Are you saying the issue is that users are presented the captive portal every time they associate and you'd like them to only accept it once?
    -or-
    Are you saying that the users remain in the captive portal redirect during their session and can't do anything else?
  • 5.  RE: IAP 6.3 WPA2-Enterprise with Portal
    Posted Jun 25, 2014 08:24 AM
    Hi Tim,
    yes, the users are remaining in the Captive Portal.
    My current goal is jus to reach a recurring captive portal as splash screen after every WLAN-Logon (with WPA2-Enterprise)...
    That a permanently save of "License accepted" flags requires ClearPass  is clear for me.
    Kind Regards
    Folke
  • 6.  RE: IAP 6.3 WPA2-Enterprise with Portal
    Posted Jun 25, 2014 08:29 AM
    We'll have to wait and see what Marcus says. As far as I know, you cannot trigger a role change from a captive portal after an 802.1X authentication without a policy server that can do a RADIUS CoA.
    The only time I've used a captive portal after an 802.1X authentication to dead-end a user and show them a "contact the help desk" style page.
