IAP 6.3.1.1-4.0.0.0 and AMP 7.6.5
  • 1.  IAP 6.3.1.1-4.0.0.0 and AMP 7.6.5
    Posted Nov 28, 2013 06:10 AM
             We have just upgraded a test site with the IAP firmware  6.3.1.1-4.0.0.0 and the usual functions of the IAP seem to be working fine however we have noted that although the VC is flagged as "up" on AMP the 3 IAP's that are the cluster for this site are all flagged as "down" - they all seem to be up and working from the VC GUI - anyone else seen this behavour?
    Regards
    Mike
  • 2.  RE: IAP 6.3.1.1-4.0.0.0 and AMP 7.6.5
    Posted Nov 28, 2013 08:27 AM
    I would try upgrading to AMP 7.7.7.
  • 3.  RE: IAP 6.3.1.1-4.0.0.0 and AMP 7.6.5
    Posted Nov 28, 2013 09:04 AM
    The response from TAG is "IAP 4.0 is not supported in 7.6, requested him to upgrade to 7.7.7" not easy for us since the last upgrade lasted weeks before the AMP estate settled down and ran without crashing, but we want Client Match so will presume that upgrading is our only option.
  • 4.  RE: IAP 6.3.1.1-4.0.0.0 and AMP 7.6.5
    Posted Nov 30, 2013 04:41 AM
    That's correct, the key lines from the latest AMP release notes:
    Aruba Instant Support
    - New Firmware Support
        Support has been added for Instant 6.2.0.0-3.3.0.0 in AirWave 7.7.0.
        Support has been added for Instant 6.2.1.0-3.4.0.0 in AirWave 7.7.2.
        Support has been added for Instant 6.3.1.1-4.0.0.0 in AirWave 7.7.7. (Template-based configuration only.)
    The 'template-based config' comment means that the Instant GUI Configuration mode (toggled on Group -> Basic) is limited to 3.2 through 3.4 at this time.
