IAP 92 is not showing on a virtual controller solution of 103 ?
  • 1.  IAP 92 is not showing on a virtual controller solution of 103 ?
    Posted Jun 13, 2015 02:04 PM
    Dear All,
    I have deployed virtual controller based soultion at different customer sites.
    Customer 1: IAP model 104 solution containing more than 40 IAP.
    Customer 2 : IAP model 103 solution containing more than 40 IAP.
    Customer 3 : IAP model 103 solution containing more than 50 IAP.
    Recently I have deployed virtual controller solution of IAP 103 (15 IAPs) at the customer site. Customer also wants to make the IAP-92 (3 iaps) to be a part of virtual controller solution. When  I connect iap-92 aps, on the virtual controller total 16 accesss points are shown 15 (103) and one (92). The remaining two IAP-92 are properly power up/stable but not showing on the virtual controller. When I power off the two iaps of model 103 then the remaining two IAP-92 which were not showing previously are now showing on the controller.
    What should i do to put all the iaps on the virtual controller?
    How much IAPs are supported on the virtual controller? Are they should be of same model ??
  • 2.  RE: IAP 92 is not showing on a virtual controller solution of 103 ?
    Posted Jun 13, 2015 08:15 PM
  • 3.  RE: IAP 92 is not showing on a virtual controller solution of 103 ?
    Posted Jun 14, 2015 03:56 AM
    Thanks for updating...
    Thumbs up
