IAP 93 Can't see Signal Issues.
  • 1.  IAP 93 Can't see Signal Issues.
    Posted Jul 10, 2012 08:56 PM
    Im completely new to Aruba. I have installed 9 IAP -93  AP's but can't see the SSID. I do not have it hidden. The network will not show up on Iphone or laptop.  The noise is a little high and the virtual controller says the signal is good but I can't see anything. Any suggestions?
  • 2.  RE: IAP 93 Can't see Signal Issues.
    Posted Jul 11, 2012 01:30 AM
    How close are you to the IAP93?  Do you have an ipad (dual band device) to check to see if you can see it?
  • 3.  RE: IAP 93 Can't see Signal Issues.
    Posted Jul 11, 2012 06:41 AM
    I wss 3 ft away from it.
  • 4.  RE: IAP 93 Can't see Signal Issues.
    Posted Jul 11, 2012 07:03 AM
    Under Maintenence, make sure that you have upgraded to the latest version.  After that, go into the Support Link, change the command to "AP Allowed Channels" and click on RUN to see what channels your APs are broadcasting on:
