IAP-93 Certificate for Captive Portal
  • 1.  IAP-93 Certificate for Captive Portal
    Posted Jun 15, 2012 06:57 AM
    I have just upgraded my IAP-93 with ArubaInstant_Orion_6.1.3.1-3.0.0.1_33617
    When I connect to my guest SSID I no longer get the invalid certificate warning when connecting to the captive portal.
    Investigation shows that there is a GeoTrust cert for securelogin.arubanetworks.com on the IAP.
    I have found no documentation that this cert is now included in the IAP firmware.
    Can someone please confirm that this cert is installed with ver3.0.0.1 and this is going to remain so in future releases.
    Nigel
