IAP 93 / Mesh ?
  • 1.  IAP 93 / Mesh ?
    Posted Aug 02, 2012 10:36 AM
    quickndirty question : Mesh via IAP93 and then local coverage with 2,4ghz or 5ghz , possible ?
     im not sure, yes they are single-band and normally dual-band is the better choice here to do mesh via 5ghz and local coverage via 2,4ghz .
    so what's possible with single band IAP 93 regarding Mesh , im always confused regarding this fact.
    regards
    ben
  • 2.  RE: IAP 93 / Mesh ?
    Posted Aug 02, 2012 04:10 PM
    IAP 93 will not do mesh.
  • 3.  RE: IAP 93 / Mesh ?
    Posted Sep 07, 2012 09:56 AM
    Sorry have to ask again while reading Datasheets of IAP93/AP93 :
    Operating Modes
        Secure enterprise mesh
    regards
    ben
  • 4.  RE: IAP 93 / Mesh ?
    Posted Sep 07, 2012 10:01 AM
    Ah it looks like mesh is for inter-IAP communication, nothing more, nothing less, correct ?
    so i think the question is answered or ?
    regards
  • 5.  RE: IAP 93 / Mesh ?
    Posted Sep 07, 2012 10:03 PM
    IAP-92/93 do not support wireless mesh. This features is only supported on IAPs that have two radio that are active at the same time, like IAP-105, IAP-135 and IAP-175.
