last person joined: 3 hours ago
IAP 93 - Power Connector quite unstable / broken
  • 1.  IAP 93 - Power Connector quite unstable / broken
    Posted Apr 24, 2012 03:40 AM
    hello,
    anyone also having experienced that on IAP93 the power connectors for the 12V power supply are quite unstable regarding physical connection? Those little connector should be replaced so we can use RAP2 power supply's too on those IAP93 and dont have to buy all the time other power supplies for every AP ...
    You remember 5V/4A on AP6x / AP12x series ,
    AP105/IAP105  have this little power connector problem too...
    regards
  • 2.  RE: IAP 93 - Power Connector quite unstable / broken
    Posted Apr 24, 2012 04:10 AM
    This is very true. I have had to resort to hot glue to keep the plugs in. Thankfully practically all deployments are PoE.
