IAP 93 PURGEENV Admin Password
  • 1.  IAP 93 PURGEENV Admin Password
    Posted Dec 22, 2011 01:56 PM
    Good afternoon guys!
    I´m new with aruba and i have a big problem with my IAPs 93. I made a reset_factory / purgeenv / save / boot and now i cannot access with admin/admin through console.
    When i put the user and password via console it just request again. Besides that the instant wirelless network don´t appear so i cannot access via browser.
    Could you please help me with this issue?
    Thank you very much!
  • 2.  RE: IAP 93 PURGEENV Admin Password
    Posted Dec 22, 2011 02:15 PM
    Did you try using the reset button on the AP?
  • 3.  RE: IAP 93 PURGEENV Admin Password
    Posted Dec 22, 2011 02:27 PM
    Yes, and I got the same problem... :(
  • 4.  RE: IAP 93 PURGEENV Admin Password
    Posted Dec 22, 2011 02:28 PM
    As suggested by colin , try the reset button. After that console into to the AP and notice the activities to see whether the AP is elected as the master, unless the IAP is elected as the master you cannot use the username/password to login to the console.
     I hope you dont have another IAP on the same layer 2 that is acting as master. You  can login only on to the IAP that is elected as master.
    Sathya
  • 5.  RE: IAP 93 PURGEENV Admin Password
    Posted Dec 26, 2011 11:32 PM
    Please try setting up the IAP in a stand-alone network after resetting, see if it works.
    If it stll does not, you can post the console output of the boot process, and one of us can check it to see if anything looks suspicious.
  • 6.  RE: IAP 93 PURGEENV Admin Password
    Posted Dec 28, 2011 06:47 AM
    Thank you very much Sathya. ]
    I think that was the problem: the IAP was not elected as master.
    Thank you!
