IAP-93 VC Problem
  • 1.  IAP-93 VC Problem
    Posted Oct 20, 2014 02:48 AM
    i have two IAP-93-US connected to the Cisco 3560 Switch. i configured the VC with the ip 172.16.16.8/24 and the iap-93 ip are 172.16.16.9/24 and 172.16.16.10/24 repectively. the iap-93 connection to the switch is trunk link because i have two ssids. now the problem is that i am not able to access the VC through the browser although internet is working fine. please assist me in this regard.
  • 2.  RE: IAP-93 VC Problem
    Posted Oct 20, 2014 08:53 AM
    Can you try going to your browser using either IP ?
    172.16.16.9 or 10
    In the trunk did you have the access unrestricted ?
  • 3.  RE: IAP-93 VC Problem
    Posted Oct 21, 2014 02:59 AM
    not able to access via brower and also not able to ping the 172.16.16.9 or 10
     below is the switch configuration for the access point
    interface FastEthernet0/11
     description CONNECTION-TO-IAP93-1
     switchport trunk encapsulation dot1q
     switchport mode trunk
    interface FastEthernet0/12
     description CONNECTION-TO-IAP93-2
  • 4.  RE: IAP-93 VC Problem
    Posted Oct 21, 2014 07:35 AM
    If you are using something else besides VLAN 1 to manage your IAPs then you need to add the native VLAN on the switch side and IAP wired port setting
  • 5.  RE: IAP-93 VC Problem
    Posted Oct 22, 2014 01:57 AM
    but i have the same scenario in different location with iap-93 rest of the world, which is working fine, any way can you guide me how to setup this wired port setting
  • 6.  RE: IAP-93 VC Problem
    Posted Oct 22, 2014 09:08 AM
    You can create a new one and then added to the the port
  • 7.  RE: IAP-93 VC Problem
    Posted Oct 22, 2014 10:50 AM
    i will try this in the weekend and then i will let you know, advance thanks for your assistance.
  • 8.  RE: IAP-93 VC Problem
    Posted Nov 01, 2014 03:02 AM
    no it did not solve my problem
